How do I restore a Cisco 1811 Router to it's default settings.
Answered Question
I'm trying to set up a Cisco 1811 router, but I think I messed up so I restored the factory defaults using this method:
Method 1
This method uses the config-register 0x2102 command in global configuration mode.
   1.
      Check the configuration register on the router by issuing the show version command.
       The configuration register setting is displayed in the last line of  the show version command output and should be set to 0x2102. If this is  not the case, enter the config-register 0x2102 command once in global  configuration mode.
          router#configure terminal
          router(config)#config-register 0x2102
          router(config)#end
          router#
       If the show version command is issued again, the same line in the  command output will have '(will be 0x2102 at next reload)' appended to  the current register setting.
   2.
      Erase the current start-up configuration on the router with the write erase command.
   3.
      Reload the router with the reload command. When prompted to save the configuration, DO NOT save.
          router#reload
          System configuration has been modified. Save? [yes/no]: n
          Proceed with reload? [confirm]
      Once the router reloads, the System Configuration Dialog appears.
                   --- System Configuration Dialog ---
          Would you like to enter the initial configuration dialog? [yes/no]:
      The router is now reset to the original factory defaults.
I  got to the line that said " Would you like to enter the initial  configuration dialog? [yes/no]:" and I quit out of the hyperteminal as I  wanted to do the configuration via the web interface (as I don't really  understand the command line yet). The problem is the router isn't  giving any ip addresses. I tried the default address (10.10.10.1) but  that didn't work. The computer won't even recognize that cat 5 cable is plugged in (I have verifyed that both the computer and cat5 cable work). All that is plugged into the router is a straight through cable coming from the modem (to get Internet) in FastEthernet 0 and a straight through plugged into port number 5 going to the computer. How can I get the router back to the settings it had when I took it out of the box. Thoses settings allowed me to simply plug in a cat 5 cable to a computer, the computer would get an ip address (usually 10.10.10.2) I would open up a web browser and type in 10.10.10.1 the web interface would pop up and I'd be good to go.
Correct Answer by d-fillmore about 6 years 4 months ago
Hi - the router comes with a config on it that allows you do just plug a pc in, get an IP address and configure it using the ASDM but you've erased this.
boot the router, go into enable mode by typing 'en' and press enter
type 'conf t' and press enter,
then copy and paste the config below in.
Once your done type 'exit' and press enter
then type 'wr' and enter
Rate this post if it helps you
Cheers, Dom
hostname yourname
logging buffered 51200 warnings
username cisco privilege 15 secret 0 cisco
ip dhcp excluded-address 10.10.10.1
ip dhcp pool sdm-pool
   import all
   network 10.10.10.0 255.255.255.248
   default-router 10.10.10.1
   lease 0 2
no ip domain lookup
ip domain-name yourdomain.com
interface FastEthernet2
no ip address
no shutdown
interface FastEthernet3
no ip address
no shutdown
interface FastEthernet4
no ip address
no shutdown
interface FastEthernet5
no ip address
no shutdown
interface FastEthernet6
no ip address
no shutdown
interface FastEthernet7
no ip address
no shutdown
interface FastEthernet8
no ip address
no shutdown
interface FastEthernet9
no ip address
no shutdown
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-FE 2$
ip address 10.10.10.1 255.255.255.248
ip tcp adjust-mss 1452
ip http server
ip http access-class 23
ip http secure-server
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 23 permit 10.10.10.0 0.0.0.7
banner login ^
Cisco Router and Security Device Manager (SDM) is installed on this device.
This feature requires the one-time use of the username "cisco"
with the password "cisco". The default username and password have a privilege level of 15.
Please change these publicly known initial credentials using SDM or the IOS CLI.
Here are the Cisco IOS commands.
username   privilege 15 secret 0
no username cisco
Replace and with the username and password you want to use.
For more information about SDM please follow the instructions in the QUICK START
GUIDE for your router or go to http://www.cisco.com/go/sdm
no cdp run
line con 0
login local
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
!  End of SDM default config file
end
Overall Rating: 5 (2 ratings)
Correct Answer
d-fillmore Thu, 08/26/2010 - 08:10
Cheers, Dom
hostname yourname
   import all
   lease 0 2
no ip domain lookup
no ip address
no shutdown
no ip address
no shutdown
no ip address
no shutdown
no ip address
no shutdown
no ip address
no shutdown
no ip address
no shutdown
no ip address
no shutdown
no ip address
no shutdown
interface Vlan1
ip http server
banner login ^
no username cisco
no cdp run
line con 0
login local
line vty 0 4
access-class 23 in
privilege level 15
login local
line vty 5 15
access-class 23 in
privilege level 15
login local
end
Nagaraja Thanthry Thu, 08/26/2010 - 11:17
Is the VLAN interface up? Also, if you give a static IP to your PC, can you
ping the router IP?
NT
VLAN is "
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;} administratively down" Perhpas that's my problem, how do I get VLAN up? If I assign a  static ip of 10.10.10.2 subnet 255.255.255.248 default gateway  10.10.10.1 and no dns to the computer I cannot ping the router.
Here is the output for show run:
Building configuration...
Current configuration : 4660 bytes
version 12.4
hostname yourname
boot-start-marker
boot-end-marker
enable secret 5 *Password*
enable password *Password*
no aaa new-model
crypto pki trustpoint TP-self-signed-2881171008
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2881171008
revocation-check none
rsakeypair TP-self-signed-2881171008
crypto pki certificate chain TP-self-signed-2881171008
certificate self-signed 01
  3082024F 308201B8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32383831 31373130 3038301E 170D3130 30383236 31363236
  32375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 38383131
  37313030 3830819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100CD4F CAA18F7B 8B7F9B7C 716D5891 4AADC83C 31ABA6A4 B73069BB 26F23138
  FF73ACB5 A1A374F9 72673702 899FF137 88D7E02C 5C729C4E BB59603F DE4F709D
  D360EA90 76F79D0F 9DE6BC45 9E7FB81C 3909CFFE F5CD7B30 C6885BA0 B3EB054B
  EC2055AA 0AAB3324 DA2D40C1 53F9E979 6A0FC598 F5FB987A 673DE613 60361150
  34910203 010001A3 77307530 0F060355 1D130101 FF040530 030101FF 30220603
  551D1104 1B301982 17796F75 726E616D 652E796F 7572646F 6D61696E 2E636F6D
  301F0603 551D2304 18301680 143B6B58 5C2572CB CE2C75D3 15FDCDE1 A3210B37
  96301D06 03551D0E 04160414 3B6B585C 2572CBCE 2C75D315 FDCDE1A3 210B3796
  300D0609 2A864886 F70D0101 04050003 81810067 5C4EF692 89856A67 DA506154
  1CF33CD5 02C1CBC9 AD22FBEF 4B8BBB1F 05EABC34 BC45C86D 157B9B89 C744B595
  1A4B10D1 5404833C 3FA9B3D8 74367E6F EB83FCCA 12021FBE C3FDEA4B 93D1F369
  75242D45 C87EA03A 13DDF228 322C37DC BA461745 8F63578B 52702ACA 654FFB66
  0079ABD9 B56EC847 2D4891EB 165B3052 E87938
        quit
dot11 syslog
no ip routing
no ip cef
no ip dhcp use vrf connected
   import all
   lease 0 2
no ip domain lookup
ip domain name yourdomain.com
username cisco privilege 15 secret 5 $1$6QOU$wa71zuRGqmxXl8zZ1aaye0
archive
log config
  hidekeys
interface FastEthernet0
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
no cdp enable
interface FastEthernet1
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
no cdp enable
no cdp enable
no cdp enable
no cdp enable
no cdp enable
no cdp enable
no cdp enable
no cdp enable
no cdp enable
interface Vlan1
no ip route-cache
shutdown
interface Async1
no ip address
encapsulation slip
no ip route-cache
ip forward-protocol nd
ip http server
no cdp run
control-plane
banner login ^C
vel of 15.
no username cisco
^C
line con 0
exec-timeout 0 0
login local
line 1
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
password *Password*
login local
line vty 5 15
access-class 23 in
privilege level 15
login local
no process cpu extended
no process cpu autoprofile hog
end
Here is the output for show int:
Async1 is down, line protocol is down
  Hardware is PQUICC3 Serial in async mode (TTY1)
  MTU 1500 bytes, BW 9 Kbit/sec, DLY 100000 usec,
  Encapsulation SLIP, loopback not set
  DTR is pulsed for 5 seconds on reset
  Last input never, output never, output hang never
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/0/16 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 6 kilobits/sec
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     0 packets output, 0 bytes, 0 underruns
     0 unknown protocol drops
     0 carrier transitions
FastEthernet0 is administratively down, line protocol is down
  Hardware is PQ3_TSEC, address is *Mac Address* (bia *Mac Address*)
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Auto-duplex, Auto Speed, 100BaseTX/FX
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 watchdog
     0 lost carrier, 0 no carrier
FastEthernet1 is administratively down, line protocol is down
     0 watchdog
FastEthernet2 is up, line protocol is down
  Hardware is FastEthernet, address is *Mac Address* (bia *Mac Address*)
  Auto-duplex, Auto-speed
     0 output errors, 0 collisions, 1 interface resets
FastEthernet3 is up, line protocol is up
  Full-duplex, 100Mb/s
     126 packets input, 17851 bytes, 0 no buffer
     Received 120 broadcasts, 0 runts, 0 giants, 0 throttles
     243 packets output, 15552 bytes, 0 underruns
FastEthernet4 is down, line protocol is down
     345 packets input, 49402 bytes, 0 no buffer
     Received 331 broadcasts, 0 runts, 0 giants, 0 throttles
     1572 packets output, 100608 bytes, 0 underruns
FastEthernet5 is up, line protocol is down
FastEthernet6 is up, line protocol is down
FastEthernet7 is up, line protocol is down
FastEthernet8 is up, line protocol is down
FastEthernet9 is up, line protocol is down
Vlan1 is administratively down, line protocol is down
  Hardware is EtherSVI, address is *Mac Address* (bia *Mac Address*)
  Description: $ETH-SW-LAUNCH$$INTF-INFO-FE 2$
  Internet address is 10.10.10.1/29
  Last input 00:07:12, output never, output hang never
     0 output errors, 2 interface resets
d-fillmore Thu, 08/26/2010 - 11:45
Which port on the router have you plugged your PC into?
go into enable mode on the router and copy and paste the output of 'show run' and 'show int'
Cheers, Dom
Related Content
