Assistance with CSS sticky-serverdown-failover
Answered Question
Aug 26th, 2010
Dear all,
I have a CISCO 11500 and configured it for sticky source ip balancing. The stickinees works fine but if the associated service stops or becomes available, the failover is not working. I have used "sticky-serverdown-failover" but this is not working. Please see the config below. If I take off the stickiness the balancing works fine
owner RMG2
content web-servers
protocol tcp
port 80
vip address 172.18.82.106
add service RMG2.2
add service RMG1.2
advanced-balance sticky-srcip
balance leastconn
Your help is greatly appreciated !!!
Cheers
Correct Answer by Gilles Dufour about 6 years 9 months ago
Do you have a probe to detect the server is down ?
Does the service shows down at the time you open a new connection ?
Gilles.
Active connections will not be failed over.
Only new connections will be redirected to the other server.
You can't simply move one connection from one server to the other.
The backup server would not accept the traffic since it did not participate in the tcp 3-way handshake and does not know about the tcp sequence numbers.
Gilles.
Overall Rating: 5 (2 ratings)
Correct Answer
Gilles Dufour Fri, 08/27/2010 - 05:03
  • Cisco Employee,
Gilles.
Onlinecomputing_2 Fri, 08/27/2010 - 05:35
Hi Gilles,
I am not worried about the active session but even if I close the browser and try a new session, it sticks to the same service even if the site is down
Correct Answer
Gilles Dufour Mon, 08/30/2010 - 00:10
  • Cisco Employee,
Gilles.
