Jaime Valencia Thu, 08/26/2010 - 09:25
  • Cisco Employee,
  • Hall of Fame,
    2011
You need to provide versions. In any case the following links cover whatever version you can have.
You can start by reading the install guide for you version.
I assume you've already went thru the system requirements and you meet all of them, if not, it's in the same link.
Install and Upgrade Guides
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/prod_installation_guides_list.html
CUCM/Unity integration guides are here
Configuration Guides
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_installation_and_configuration_guides_list.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Related Content
