Changing ACS to Network Devices Groups
Aug 26th, 2010
If I cahnage my ACS Servers to support Network Devices Groups
Will I loss all the defined devices or are they moved to a default Group, which will then allow me to move them around ?
Przemyslaw Konitz Fri, 08/27/2010 - 01:32
Im not sure what u are asking.
what ACS version do you use?
In ACS5.1 there is no problem with  deleting groups which are used by devices (but there can't be any reference to these groups in policies)
i.e. when one device is in specific group which I try to delete there is only a warning and that device is moved to it's root node.
Ian Beck Fri, 08/27/2010 - 05:14
Thanks for the reply.
Iam running 4.2 and do not want to delete but enable Groups.
At present we don't use Network Groups and my cocenr is, when I enable it what will happen to all my defined devices.
If I don't loss them I should then be able to create relevant groups and move devices into them.
Its the enabling part that concerns me, as it says that all I will have to two options on screen.
