Can a failover incomming Dial-plan be configured?
Aug 26th, 2010
  • Bronze, 100 points or more
Had a disappointing situation occur to our in-house UC520 this week. Sometime on Saturday 8/21, our office experienced a power failure. This failure caused an internal module that CUE runs it's image file off of to become corrupt. Hence voicemail and AA no longer function.
The crappy part is that outbound calls were able to be made as normal.
Long story short, we did not know our AA wasn't picking up inbound calls until 4 days into this. And I imagine some of our customers were unable to reach us, unbeknownst to us.
My question is, Is there any way to have a failover inbound dial-plan for situation where the AA is not reachable. Maybe have all call forward to a blast group that way we can avaid this in the future?
Thanks.
Brian
www.jaydien.com
antyeung Thu, 08/26/2010 - 14:32
This is not possible from CCA. However, it's possible from the CLI (and not pretty) but you would have to test it out.
Assuming this is your dial-peer to CUE-
dial-peer voice 2000 voip
  destination-pattter 399
  session protocol sipv2
  session target ipv4:10.1.10.1
  dtmf-relay sip-notifcy
  codec g711u
  no vad
Add another dial-peer that routes the call to itself w/ the same destination-pattern
dial-peer voice voip
  destination-pattern 399
  incoming called
  ipv4:x.x.x.x
  codec g711u
  no vad
  pref 1
  translation-profile outgoing xlateToHuntPilot
In the translation profile translate the called number 399 to the blast group pilot.
What I think should happen is when you call 399 and it gets sent to CUE and fails the call would attempt to route to the second dial peer where you translate the called number to itself. Since the called number was xlated to the blast group pilot on the incoming it should route to the blast group.
-Anthony
jaydien1358 Fri, 08/27/2010 - 09:08
Thanks but that isn't as clean as I was hoping.
Is this something that has been tested at all? Does anyone else have an idea of how to do this cleannly?
Thanks.
-Brian
www.jaydien.com
antyeung Sun, 08/29/2010 - 17:39
This has not been tested, but it should work. You'll need to test it to verify that it does what you want.
The only way for CME to know that CUE is in an inoperable state is for CME to extend a call to CUE and for it to fail. You can make use of the "monitor probe icmp-ping" feature configurable under the dial peer where CME would send ICMP pings to the destination you specify. If ICMP ping fails the dial peer status would change. However this may not be what you want since CUE may still be pingable (interface UP), yet the CUE software may be inoperable. Also, you'll still need to configure a secondary dial peer where you'll need to loop it back to itself.
AFAIK, there isn't a cleaner way to achieve failover w/out manual intervention.
If others have ideas/suggestions I would be interested in hearing them.
Anthony
