08-26-2010 02:05 PM - edited 03-04-2019 09:33 AM
Does the 3825 support ipv6?
If so how do you enable it?
i am running the advanced security 15.1(2) software.
Solved! Go to Solution.
08-26-2010 02:57 PM
Feature set on a 3825 means software image.
For licensing issues, contact your cisco sales office or reseller.
Please remember to rate useful posts clicking on the stars below.
08-26-2010 02:18 PM
3825 supports IPv6 but you need to change features set from security to Adv IP or Enterprise or SP.
Here is config guide.
conf t
ipv6 unicast-r
int x/x
ipv6 address 2001:0DB8:0:1::x/64
KK
08-26-2010 02:30 PM
Thats what i thought and i looked at that document. But the commands are not there.
there is no: ipv6 cef , or ipv6 cef distributed.
there is no ipv6 address cmd under the interface.
any ideas?
08-26-2010 02:43 PM
Read the post above:
08-26-2010 02:52 PM
are the feature set the same and what about license? the reason we had to go with security was to use parts of bgp at version 12.4.
08-26-2010 02:56 PM
It is up to the contract you have with CISCO.
You can try to download IOS from www.cisco.com/tac. Login with your CCO ID.
If your contract is good enough, you can download ADV IP from http://www.cisco.com/cisco/web/download/index.html
ADV IP will have all BGP supports, so you can download ADV IP feature set.
KK
08-26-2010 02:57 PM
