Cisco 2811 Router with 3 ADSL WAN Wic’s.
Aug 26th, 2010
Cisco 2811 VPN
I have previously posted this question but somehow it ended up being marked as answered!! so here goes again.
I have a Cisco 2811 Router with 3 ADSL WAN Wic’s.
I  have a number of remote sites that I want to setup via a site to site  VPN link. Setting this up via the first WIC or other WIC is no problem  however when I setup a number of sites to use the first WIC and proceed  to setup additional sites using the second or third WIC I keep getting  phase one errors.
As soon as I reconfigure my remote router with the peer address of the first WIC on the 2811 it connects without any problems.
Any suggestions please.
To sumarise,
Cisco 2811 VPN connection via ADSL WIC 1 to Cisco 877 ADSL (remote site 1) connects without problem
Cisco 2811 VPN connection via ADSL WIC 2 to Cisco 877 ADSL (remote site 1) connects without problem
Cisco 2811 VPN connection via ADSL WIC 3 to Cisco 877 ADSL (remote site 1) connects without problem
Cisco 2811 VPN connection via ADSL WIC 1 to Cisco 877 ADSL (remote site 1 and 2) connects without problem
Cisco 2811 VPN connection via ADSL WIC 1 to Cisco 877 ADSL (remote site 1) connects without problem and at the same time
try Cisco 2811 VPN connection via ADSL WIC 2 to Cisco 877 ADSL (remote site 2) unable to connect with phase one errors
If I setup a VPN tunnel from both remote sites to WIC 2 on the Cisco 2811 everything is okay again, it doesn't seem to like when I am
trying to setup each site to a different ADSL WIC. Each ADSL WIC has it's own phone line and IP address.
I have been trying to get this to work for a while but have not had any success.
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(24)T3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 23-Mar-10 06:43 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
system uptime is 10 weeks, 6 days, 10 hours, 10 minutes
System image file is "flash:c2800nm-advipservicesk9-mz.124-24.T3.bin"
Yudong Wu Thu, 08/26/2010 - 22:58
  • Gold, 750 points or more
can you post your 2811 configuration?
If you ran "debug cry isa" when it did not work, please provide the debug output as well.
peterv Thu, 09/02/2010 - 00:36
Thanks for the reply, I will post some debug info and config details as soon as I can.
