Cisco AP 1242AG Config Got Hosed
Answered Question
Aug 26th, 2010
I have an AP that was LWAPP on a WLC but during an upgrade it is one the got hosed.  When it boots up, it just stops and shows Red lights.  I have consoled into it and it will start to boot and then give Error loading "Flash:/update/c1240-k9w8-mx.124-18a.JA2/c1240-k9w8-mx.124-18a.JA2.
Interrupt within 5 seconds to abort boot process
boot process failed...
The system is unable to boot automatically.  The BOOT environment needs to be set to a bootable image.
Well, I have a new image, but my question is how do I get this into the AP with the console cable.  Do I use xmodem or something like that.  Once the AP goes to the point where it shows ap:  then it is stopped.  There is no typing or anything that will work.  Anyone have a link that explains how to put code into an AP with a bad boot image or can you explain how to do this.  I would surely appreciate it.
Correct Answer by Leo Laohoo about 6 years 1 month ago
Using a TFTP Server to Return to a Previous Release
Please don't forget to rate our useful posts.  Thanks.
Overall Rating: 5 (1 ratings)
stalljoseph Thu, 08/26/2010 - 20:21
Thank you!!!! I just love you all (in a respectful way, of course)!!!!!
Leo Laohoo Thu, 08/26/2010 - 20:34
Thank you very much for the ratings.  Glad to be of some form of assistance.
