08-26-2010 09:26 PM
Hi All,
I have MARS version 6.0.3 (3188) 32, when i try to add IDSM2 to it as a device i can't find the version of the IDSM2 in the MARS.
version of IDSM2 is 7.0.4(E4).
can anyone help me in this issue please.
Thanks in advance,
Ayman
Solved! Go to Solution.
08-30-2010 03:54 AM
Aymen;
The upgrade process for CS-MARS is outlined here:
http://www.cisco.com/en/US/docs/security/security_management/cs-mars/6.0/initial/configuration/upgrade.html
The upgrade does not affect your existing configuration and incident data.
A standalone CS-MARS is the equivalent of a local controller in this
document.
Scott
09-03-2010 03:30 AM
Ayman;
CS-MARS will successfully parse signature events for your IDSM-2
running 7.0 software. However, CS-MARS will have no understanding of
the global correlation details which are new to the 7.0 release. If you
wish to be able to query/report on global correlation details within
CS-MARS, you will need to upgrade.
Once you upgrade, you can simply select the IDSM-2 in the 'Security
and Monitor Devices' list and click the "Change Version" button.
Scott
08-27-2010 05:36 AM
IPS 7.0 support was added in CS-MARS release 6.0.4.
Scott
08-29-2010 07:59 AM
HI Scott,
How can i upgrade from 6.0.3 to 6.0.4 and does the upgrade of the MARS will affect the configuration or not ???
Thanks in advance
Ayman Yehia
08-30-2010 03:54 AM
Aymen;
document.
Scott
09-03-2010 12:53 AM
Hi Scott,
Thanks for the links but i managed to add the IPS as version 6 and it worked fine with the MARS.
Ayman
09-03-2010 03:30 AM
Ayman;
Scott
