AAA Authentication on Router
Aug 26th, 2010
We have a Cisoc 2901 ISR G2 router and I used Cisco Config Professional for security audit and enabled all the default security features. After this when I telnet into the router, it accepts only the local usernames and not from AAA server. In order to enable the AAA authentication on VTY interfaces do I need to enable any specific AAA commands or just remove the commands "authorization exec local_author and  login authentication local_authen"?
aa authentication login default group tacacs+ local
aaa authentication login fallback group tacacs+ enable
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 0 default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
aaa session-id common
tacacs-server host X.X.80.55
line vty 0 4
access-class 11 in
password 7 XXXXXXXXXXXXXXXXXX
transport input ssh
transport output ssh
Sven Hruza Thu, 08/26/2010 - 23:45
  • Bronze, 100 points or more
yes, I think you can remove the "login authentication local_authen" and then it should go over TACACS+.
If TACACS+ is not available the fallback is local user.
     aaa authentication login default group tacacs+ local
What the command "aaa authentication login fallback group tacacs+ enable" should do, I don't know.
But maybe you need some commands in the AAA part for the authorization.
At the moment you have only a way for authentication.
I think something like
     aaa authentication enable default group tacacs+ enable     -> for moving to enable mode
     aaa authorization exec default group tacacs+ local     -> for starting an exec shell
is needed for authorization.
And then you can remove the command "authorization exec local_author".
Sven
