Cisco1941W error massage "%DOT11-7-AUTH_FAILED: Station 0011.f596.eecb Authentication failed"
Aug 26th, 2010
I am using Cisco1941W.
When I connect CliantPC to Wireless(1941W) I got bellow massage from 1941AP.
And I couldn't ping from my PC to AP and Router.
Its possible communication from AP to Router.
I show 1941AP configration.
Could you find wrong?
By the way, my PC connected to AP by 108Mbps.
But my PC supported only 802.11a/b/g .
My PC use Static IP Address and use TEST-2  ssid.
I couldn't find error from my PC.
(start)
hostname TEST
enable secret test
aaa new-model
aaa group server radius rad_eap
server 10.73.12.2 auth-port 1645 acct-port 1646
aaa session-id common
dot11 syslog
dot11 ssid TEST-1
   vlan 100
   authentication open eap eap_methods
   authentication key-management wpa
   mbssid guest-mode
dot11 ssid TEST-2
   vlan 200
   authentication open
   mbssid guest-mode
   wpa-psk ascii testtesttesttesttest
dot11 aaa csid ietf
username Cisco password 7 05280F1C2243
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
no shut
encryption vlan 100 mode ciphers aes-ccm
encryption vlan 200 mode ciphers aes-ccm
ssid TEST-1
ssid TEST-2
mbssid
antenna gain 0
station-role root
interface Dot11Radio0.100
encapsulation dot1Q 100 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.200
encapsulation dot1Q 200
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
no shut
ssid TEST-1
ssid TEST-2
antenna gain 0
no dfs band block
channel 5180
station-role root
interface Dot11Radio1.100
no ip route-cache
bridge-group 1
interface Dot11Radio1.200
no ip route-cache
bridge-group 2
interface GigabitEthernet0
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
bridge-group 5
no bridge-group 5 source-learning
bridge-group 5 spanning-disabled
no shut
interface GigabitEthernet0.100
no ip route-cache
bridge-group 1
interface GigabitEthernet0.200
no ip route-cache
bridge-group 2
interface BVI1
ip address 10.73.12.7 255.255.255.0
no ip route-cache
ip default-gateway 10.73.12.1
ip http server
no ip http secure-server
radius-server deadtime 1440
bridge 1 route ip
(end)
I guess errer massage is telling Radio Frequency error.
I tried to change configuration "speed".
But still get error massage and I couldn't ping from my PC.
Leo Laohoo Fri, 08/27/2010 - 02:38
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
What SSID?  Test-1 or Test-2?
Authentication failed possibly because the PSK wasn't entered correctly.
Can the client associate Test-1 (open authentication)?
iotoiotoioto Fri, 08/27/2010 - 04:16
Thanks, leolaohoo.
so I use TEST-2.
in this case, ignore TEST-1.
I just paste real configuration.
I tried to connect again.
But still I can't ping from PC to AP.
I use other PC.
I configured bellow.
  -interface dot11Radio0
  -speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
It was same resault.
Is cisco1941w broken?
I'd like to know one more.
I configured bellow, but I couldn't use 802.11a.
  -shutdown
how to use 802.11a(5GHz)?
