Can we run CVP 8.0 voice apps on VXML servers 4.0?
Aug 26th, 2010
I have a peculiar situation where we need to set a new development system for CVP and I expect the version to be version 8.0. However, my prod. environment is running version 4.0.  The big question for me is that if I migrate my voice apps to version 8.0 within CVP studio and try to deploy and run on a production vxml server version 4.0, will it work? Likely to break, correct ...
david.macias Fri, 08/27/2010 - 10:52
  • Blue, 1500 points or more
Yes, it should work just fine, just reopen the apps and redeploy them.  Depending on the complexity of your applications everything should be good.
david
