shdsl ( ethernet ) failover to 3G HWIC using BGP - 1941w
Answered Question
Aug 26th, 2010
I'm having problems with the following config. I cannot work out how I am supposed to perform the natting.
The BGP route is active as the default route when I type "sh ip route",  and if BGP route is lost the floating static (default) route takes it place as the Admin Distance of 200 kicks in. If the BGP route comes back online it replace the floating static, becoming the new static.. As it should.
However how do I dynamically NAT out to the internet so that when the main link drops, the traffic then swaps to go out dialer 0 (associated with cellular0/0/0 of the 3g link) ?
I cannot "ping www.google.com source 192.168.100.1" when dialer0 kicks in as default route. My natting is wrong, but what options do I have?
Any help would be much appreciated.
Michael.
version 15.0
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
service-module wlan-ap 0 bootimage autonomous
no ipv6 cef
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.100.1
ip dhcp pool LAN_POOL
   network 192.168.100.0 255.255.255.0
   dns-server 203.50.2.71 139.130.4.4
   default-router 192.168.100.1
ip domain name direct.telstra.net
ip name-server 203.50.2.71
ip name-server 139.130.4.4
chat-script extranet "" ATDT*98*2#" TIMEOUT 30 CONNECT
chat-script internet "" "ATDT*98*3#" TIMEOUT 30 CONNECT
license udi pid CISCO1941W-N/K9 sn *******
username *********** privilege 15 secret ******
username ******** privilege 15 secret *****
ip ssh version 2
interface Loopback0
ip address 128.1.1.1 255.255.255.255
interface Wlan-GigabitEthernet0/0
description Internal switch interface connecting to the embedded AP
interface GigabitEthernet0/0
backup interface Dialer0
ip address 139.*.*.2 255.255.255.252
ip nat outside
ip virtual-reassembly
duplex full
speed 100
interface wlan-ap0
description Service module interface to manage the embedded AP
no ip address
arp timeout 0
no mop enabled
no mop sysid
interface GigabitEthernet0/1
ip address 192.168.100.1 255.255.255.0
ip nat inside
no ip route-cache cef
duplex auto
speed auto
interface Cellular0/0/0
no ip address
encapsulation ppp
load-interval 60
dialer in-band
dialer pool-member 1
async mode interactive
no fair-queue
interface Vlan1
no ip address
interface Dialer0
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer string extranet
dialer persistent
ppp authentication chap callin
ppp chap hostname ******
ppp chap password ******
ppp ipcp dns request
ppp multilink
no fair-queue
no cdp enable
router bgp 65000
no synchronization
bgp log-neighbor-changes
neighbor 139.*.*.2 remote-as 1221
neighbor 139.*.*.1 description *************
no auto-summary
ip forward-protocol nd
ip http server
ip http secure-server
ip nat inside source list 33 interface GigabitEthernet0/0 overload
ip nat inside source list 22 interface dialer 0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0 200
access-list 22 permit 192.168.100.0 0.0.0.255
access-list 33 permit 192.168.100.0 0.0.0.255
control-plane
line con 0
transport output all
line aux 0
line 0/0/0
exec-timeout 0 0
script dialer extranet
modem InOut
no exec
rxspeed 7200000
txspeed 2000000
line 67
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 2
access-class 22 in
exec-timeout 20 0
login local
transport input telnet
line vty 3 4
exec-timeout 20 0
login local
transport input ssh
scheduler max-task-time 5000
scheduler allocate 20000 1000
end
Correct Answer by Giuseppe Larosa about 6 years 4 months ago
Hello Mike,
you need to add more intelligence to NAT operations using route-maps
see
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080093fca.shtml
by using match interface you can use an appropriate pool for the active interface
route-map SmartNAT1 permit 10
match interface g0/0
match ip address 33
route-map SmartNAT2 permit 20
match interface dialer0
match ip address 22
change nat rules in
ip nat inside source route-map SmartNAT1 interface ge0/0 overload
ip nat inside source route-map SmartNAT2 interface dialer0 overload
if interface option is not accepted you should configure nat pools
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Fri, 08/27/2010 - 02:35
Hello Mike,
see
match ip address 33
match ip address 22
change nat rules in
Hope to help
Giuseppe
cco4mike1 Sat, 08/28/2010 - 00:00
Thankyou Giuseppe,
I will try that when I go back to site on Monday(today Sat)
I was thinking of using Routemaps but was unsure how the logic would differ to what I already have
It does make sense that you should bind the each NAT statement (inside source) to its respective interface however.
I'm guessing that my config, when the link failsover to 3G, the router still uses the first NAT statement in the list? (ie...int g0/0 overload)
I'll keep you posted.
regards,
Michael
Related Content
