Call Back gives Unknown number
Aug 27th, 2010
A costumer has 9971 phones. When i use the call back feature and I do call back the other phone rings but the caller sees unknown number. Even if the call is answered. (i use ucm 8.02)
I tested it in my lab but it works fine. I don't understand what the problem might be.
With kind regards,
Martijn.
Christopher Graham Fri, 08/27/2010 - 16:42
Call flow?  Protocols?  We need more info in order to help.  Are you calling out to the PSTN, or internal IP to IP?  Debugs would also be helpful assuming we're going out to the pstn.  Is this a PRI or SIP trunk.
More details please.....
mgruyters Mon, 08/30/2010 - 04:33
UCM version 8.02c
problem exist internal! between two 9971 phones (SIP)!
