Giuseppe Larosa Fri, 08/27/2010 - 05:47
  • Hall of Fame,
    Founding Member
Hello Tarik,
it may be possible but you need to be aware that your device can experience a noticeable increase in cpu usage.
I would not try this on a router less then C7200.
if you are migrating to E3 links over flexwan or SIP linecards in C6500/C7600 be aware that MLPPP is not supported there on interfaces of different port adapters.
Hope to help
Giuseppe
tarik sayel Fri, 08/27/2010 - 19:34
Hello Giuslar,
I want to implement the multilink on router 7204VXR.
There is no limit bandwidth to use Multilink ? so is it possible to do that over the E3 cards 34Mox2= 68Mo  ?
Thanks for your help.
