AP541N-K9-1.9(2) - Service Degradation
Aug 27th, 2010
I have 4x AP-541N clustered on my network, connected via Ethernet to a network switch.  I think I have experienced most of the problems previous posters have mentioned.  Can a member of Cisco support provide an update regarding degradation of service?  At any given time, it would appear that 1 of my 4 AP's is suffering from poor signal strength, the AP is always different.  The symptoms can last between 1-5 hours, the event log does not indicate that there is a problem.  The user experiance's an average data transfer rate of between 1-5 Mbps or alternatively, the network appears unavailable.
Is the advise below the only suggested fix;
Try to just disable 'Key Refresh' in each VAP.   Set the Broadcast Key Refresh Rate to 0 for each vap that does WPA(personal or enterprise).
I look forward to receiving a reply.
Paul Mitchell
Related Content
