Dual-homed server to two Cat4948 switches
Answered Question
Aug 27th, 2010
Hello everyone,
I have a picture above which I want to realize. The main point is a dual-homed server connected to two switches.
At server OS needed to configure NIC teaming which uses LACP. But how I can do it at Catalyst 4948?
Which technology I able to use to multi-switch etherchannel?
If I need one more link between Cat4948, then I can do.
Correct Answer by Lucien Avramov about 6 years 7 months ago
Correct, you can have Active/Passive, but no dual homed with active / active unless you have Nexus devices or VSS capable Cat6k.
However in this diagram, if you can bypass the 4948, then you can have active / active with vPC and connect the servers on the Nexus 7000s.
Correct Answer by Atif Awan about 6 years 7 months ago
I do not believe you can accomplish this with 4948s. You need something along the lines of vPC (Nexus) or VSS (6500) to be able to do this as the upstream switch pair needs to behave as a single logical device for LACP. What you can do is run the server in Active/Standby mode or if you want better load distribution then something along the lines of Transmit load balancing (TLB) may work.
Atif
P.S: Stackable switches like 3750 should also allow you to do LACP across two switches.
Overall Rating: 5 (2 ratings)
Correct Answer
Atif Awan Fri, 08/27/2010 - 09:13
  • Cisco Employee,
Atif
Correct Answer
Lucien Avramov Fri, 08/27/2010 - 09:16
  • Red, 2250 points or more
Yury Makurin Tue, 08/31/2010 - 04:14
Thank you for answers.
Atif, could you clarify at which layer to implement Active\Standy? At application layer? At OS layer? or Network cards?
And could you please give me link for description of TLB?
Atif Awan Tue, 08/31/2010 - 08:47
  • Cisco Employee,
The exact load sharing options available to you will probably depend on the server type / vendor. The settings are applicable to the Network Adapters but you usually use the configuration utility provided by the respective vendor. I would suggest you do a quick google search on your particular server model. An example is:
http://www.brianmadden.com/blogs/guestbloggers/archive/2006/04/19/hp-proliant-network-adapter-teaming-explained.aspx
Atif
Related Content
