ASA 8.3 and MSN Socks Proxy transparent redirect
Aug 27th, 2010
In my company have a tool to control msn traffic, this tool is a Socks proxy, that control the msn contacts, etc... The Tool is installed in a server Linux, in port 1080. I need redirect the traffic from my internal network with MSN port (1863) destination is redirected to socks proxy at my internal server (Linux). how i can make this rule?
Scott Nishimura Fri, 08/27/2010 - 11:54
you can do a static port redirection..   Heres an example:
object network obj-
nat (inside,outside) static service tcp 8080 80
The above example is showing that clients will use port 80 to get to the server on port 8080.
You can adapt the above to your specific needs.
let me know if that is what you are looking for.
