1841 VPN to ASA 5550
Aug 27th, 2010
We currently have a Cisco 1841 configured with an L2L VPN to an ASA 5550.  All appears to be working, but sometimes on the router I issue the "sh crypto ipsec sa" command and I see the association, but if I then issue "crypto isakmp sa" it shows no associations..
Why would there be IPSEC associations but no ISAKMP association?
Can anyone point me in the right direction?
Yudong Wu Fri, 08/27/2010 - 10:03
  • Gold, 750 points or more
I think this might be an expected behavoir.
show crypto isa sa --> phase 1 status
show crypto ipsec sa ---> phase 2 status.
Phase 1 and phase 2 have different timeout value.
Before phase 2 SA is close to expiration, system will negociate a new one since we need it to encrypted and decrypted the traffic.
But we don't do the same on phase 1 SA. We will re-negociate phase 1 SA only when we need re-build phase 2 SA and find no phase 1 SA existing.
You can confirm the above the behavior by checking both phase 1 (show crypt isa sa detail) and phase 2 timer.
Phase 2 use both KB/second as timer, default is about 4G/1 hours.
Phase 1's timer by default is 24 hours.
