08-27-2010 06:38 AM
Hi..
I'm trying out ACE Appliance 4710 and I've setup a basic configuration to load balance a server using one arm deployment with source NAT'ing.
Client facing side is 172.16.1.0/24
Server facing side is 192.168.1.0/24
I've one server which can be accessed with the URL https://172.16.1.10:8443 (I'm not doing SSL offloading) and the VIP for this server is 192.168.1.10.
Can anyone help me verify my config where has gone wrong? I need to be able to load balance using a custom port on the server rather than port 80.
I've not been able to access this webpage via https://192.168.1.10:8443 via the below ACE 4710 config.
However, I've no problem accessing this device using https://172.16.1.10:8443.
The below show service-policy shows all the connections being dropped.
Many Thanks!!
access-list everyone line 8 extended permit ip any any
access-list everyone line 16 extended permit icmp any any
probe icmp ICMP
interval 15
passdetect interval 60
rserver host web1
ip address 172.16.1.10
inservice
serverfarm host webfarm
probe ICMP
rserver web1 8443
inservice
class-map type management match-any REMOTE_ACCESS
2 match protocol ssh any
3 match protocol telnet any
4 match protocol snmp any
5 match protocol http any
6 match protocol https any
7 match protocol icmp any
class-map match-all webfarm_CLASS1
2 match virtual-address 192.168.1.10 any
policy-map type management first-match REMOTE_MGMT_ALLOW_POLICY
class REMOTE_ACCESS
permit
policy-map type loadbalance first-match L4_SLB_POLICY1
class class-default
serverfarm webfarm
policy-map multi-match L4_SLB_POLICY_MM
class webfarm_CLASS1
loadbalance vip inservice
loadbalance policy L4_SLB_POLICY1
loadbalance vip icmp-reply active
nat dynamic 10 vlan 10
interface vlan 10
description -- Client-facing VLAN & Management VLAN --
ip address 192.168.1.100 255.255.255.0
access-group input everyone
nat-pool 10 192.168.1.20 192.168.1.32 netmask 255.255.255.0 pat
service-policy input REMOTE_MGMT_ALLOW_POLICY
service-policy input L4_SLB_POLICY_MM
no shutdown
interface vlan 110
description -- Server-facing VLAN --
ip address 172.16.1.100 255.255.255.0
no shutdown
ip route 0.0.0.0 0.0.0.0 192.168.1.50
When I try to connect to https://192.168.1.10:8443, I get the below result.
ACE01/Test# sh rserver
rserver : web1, type: HOST
state : OPERATIONAL (verified by arp response)
----------connections-----------
real weight state current total
serverfarm: webfarm
172.16.1.10:8443 8 OPERATIONAL 1 1
rserver : web2, type: HOST
state : INACTIVE
ACE01/Test# sh service-policy
Policy-map : L4_SLB_POLICY_MM
Status : ACTIVE
Interface: vlan 1 10
service-policy: L4_SLB_POLICY_MM
class: webfarm_CLASS1
nat:
curr conns : 0 , hit count : 0
dropped conns : 0
client pkt count : 0 , client byte count: 0
server pkt count : 0 , server byte count: 0
conn-rate-limit : 0 , drop-count : 0
bandwidth-rate-limit : 0 , drop-count : 0
loadbalance:
L7 loadbalance policy: L4_SLB_POLICY1
VIP ICMP Reply : ENABLED-WHEN-ACTIVE
VIP State: INSERVICE
Persistence Rebalance: DISABLED
curr conns : 1 , hit count : 41
dropped conns : 39
client pkt count : 651 , client byte count: 38340
compression:
bytes_in : 0 bytes_out : 0
Compression ratio : 0.00%
Gzip: 0 Deflate: 0
compression errors:
User-Agent : 0 Accept-Encoding : 0
Content size: 0 Content type : 0
Not HTTP 1.1: 0 HTTP response error: 0
Others : 0
Solved! Go to Solution.
08-27-2010 10:55 AM
yes if you really want to do one arm then vlan 110 would be removed from the ace, and the server would be pointing to an svi for vlan 110 as its default gateway. and you would nat on vlan 10 on the ace.
as far as the serverfarm config if you want the ace to do port redirection then you would need the port on the serverfarm.
say the client hits the vip on port 443 and you want to send it to the server on port 8443 then you would need the port on the serverfarm
if client hits the vip on 8443 then you would not need it.
regards
08-27-2010 08:47 AM
Problem here is that it is not really one arm. In one arm client and server traffic is on the same vlan. Your client traffic comes in on vlan 10 but your server lives on vlan 110 and is layer 2 adjacent to the ace. Hence the traffic will not be natted since vlan 10 is not used as the egress to the server.
If you don't want to have the server point to ace as default gateway then you need to change nat.
put a nat pool on vlan 110 such as:
interface vlan 110
nat-pool 1 172.16.1.101 172.10.16.101 netmask 255.255.255.0 pat
no shutdown
then use it in you l4 policy map
nat dynamic 1 vlan 110
regards
08-27-2010 09:25 AM
Got it...
Correct me if I'm wrong.. if I want to do a proper one-arm deployment, I would need to modify the config to the below..
Remove vlan 110 from the Test context in the ACE appliance..
Then have the server's default gateway pointing at the switch's SVI..
--------------Switch-----vlan 110------server (default gw = switch vlan110's SVI)
| vlan 10 (nat dynamic 10 vlan 10)
ACE
Also, is my L4 load balancing policy correct?
I mean do I really need to configure
probe ICMP
rserver web1 8443
inservice
Or I can leave out the 8443 port number?
Thanks.
08-27-2010 10:55 AM
regards
08-28-2010 06:55 AM
Many thanks for pointing this out...
I did the changes today and it's all working now.
However, there are some glitches. I'm not sure whether it's the ACE appliance behaviour or not as once I've made changes, it seems that I'm getting ARP_FAILED with "show rserver". However, I can ping to the server from the ACE appliance as well as "show probe " shows successful probes "passed".
I did a reboot on the ACE and then it's working. "show rserver" displays OPERATIONAL.
08-31-2010 03:54 PM
Steven-
This is common when you modify an interface where an Rserver lived (i.e. move the ip from vlan 200 to 300 without rebooting.)
These are tracked under the following bugs:
CSCsi61783 fixed in 2(1.6) and beyond on the ACE module.
CSCte78786 fixed in 3(2.6) and beyond on the ACE 4710 Appliance.
Information on the bugs can be found in the Bug Toolkit:
http://tools.cisco.com/Support/BugToolKit/action.do?hdnAction=searchBugs
There are other flavors of the same type of issue but caused by different triggers which are fixed in other versions. Most are fixed in the most recent versions for the module and appliance codes.
Chris Higgins
