Howto? Anonymous outgoing SIP call [[email protected]]
Aug 27th, 2010
we are currently in the process to get our UC540 certified by a swiss cable SIP provider, the final test we need to pass is the anonymous outgoing call (hiding caller id) which is initiated by sending [email protected] in the SIP Invite-URI (see
From: "Anonymous" <sip:[email protected]>;tag=1928301774
Now our questions:
- How can we set this (CLI preferred) permanently for a single extension
- Is it possible to do this case-by-case using a SPA525G phone?
Any help on this would be greatly appreciated, thank you!
Overall Rating: 5 (1 ratings)
antyeung Fri, 08/27/2010 - 10:11
Can you try configuring the following-
voice service voip
   privacy header
webmasterware Mon, 08/30/2010 - 05:10
Hi Anthony,
thanks a lot, this works as global setting.
Final question regarding this: Is it possible to configure this
- for single extentsions only
- case-by-case (e.g. by dialing some code before the number like *31# for example on european ISDN)
Best regards
antyeung Mon, 08/30/2010 - 08:27
You can try using sip profiles at the dial peer level-
voice class sip-profiles 1
request ANY sip-header From modify "From: .*>" "From: \"Anonymous\" "
dial-peer voice 1 voip
  voice-class sip profiles 1
And then create a destination pattern to match your specific star code or use cor-lists to restrict who can use that dial peer.
I didn't test this in the lab so you may need to tweak this to suit your needs. But hopefully this should give you some ideas.
Purna Wijenayaka Mon, 04/22/2013 - 07:43
Hi ,
we are receiving this
Anonymous" ;
can we write a SIP manipulation rule to change this as follows ?
117416000 " ;
please advice
ausjustin Sun, 10/25/2015 - 21:17
Hi Purna
have you fixed this yet ? i am looking for same solution .
