Prevent multiple user login cisco ACS
Aug 27th, 2010
Hi All,
I have a group setup in Cisco ACS (V4.2) which holds dynamic users that have successfully authenticated through wireless. No problem. The users in this group have authenticated from a guest wireless setup. I want to prevent the same user from logging in multiple times.
For example, the project users credentials suppplied bya library ticket which is usique to that user, I want to prevent that user from giving their details to someone next to them and getting them to use their laptop. Preventing multiple logins would prevent this.
Can I do this in ACS anywhere??
Waris Hussain Fri, 08/27/2010 - 10:53
I am not sure if you can do that from the ACS side for dynamic users but in WLC there is command which you try to limit simultaneous user access :
config advanced eap max-login-ignore-identity-response {enable |
disable}
the disable option should work for you.
Here is the doc :
http://www.cisco.com/en/US/docs/wireless/controller/7.0/command/reference/cli70commands.html#wp9681830
Waris Hussain.
