Software Distribution Errors
Aug 27th, 2010
We would like to use Ciscoworks to perform our image upgrades, however, it seems we would have to delete the existing images from flash prior to performing the upgrade.
Everytime we try we get the following error:
Catastrophic - SWIM1200:Selected Flash partition requires minimum (16 MB) to upgrade selected software/image.
Select a different Flash partition for upgrading the image.
And we can not continue.
I had thought that ciscoworks used the over-write option, and this would not be an issue.
Do we have to delete the images in flash prior to the upgrade, or is there another option we should be using?
We can perform the upgrade via CLI-- using the following command
archive download-sw /ov tftp://X.X.X.X/c3750-ipbasek9-tar.122-50.SE3.tar
pxcamp19 Fri, 08/27/2010 - 12:08
Hi Sven-
Thank you so much for helping us:)
We are running LMS 3.2- and no matter what  we try, we get the same critical error.   We have not thought to edit the image attributes,
Pat
Related Content
