ASA Syslog config question
Answered Question
Aug 27th, 2010
Hello All,
I can't seem to get ASA authentication request, or config changes alerts to be forwarded to our syslog server.  I'm able to see all normal ASA messages, blocked messages, VPN authenications, etc, but if I fail a login, or make config changes it does not show up in our syslog server.  Here is the logging config:
logging enable
logging timestamp
logging list Failover level errors class ha
logging buffered informational
logging trap informational
logging asdm informational
logging from-address [email protected]
logging recipient-address [email protected] level critical
logging device-id hostname
logging host inside NAC-Syslog
logging class auth console notifications trap informational asdm notifications
logging class config console notifications trap informational asdm notifications
I've turned up every level I could think of to informational, done multiple google searches and I am at a loss.  This is something we have to show for compliance, and is one of my last open issues so any help is greatly appreciated
Shawn
Correct Answer by scbrinke about 6 years 9 months ago
Hi Shawn,
Your configuration looks correct to be sending the syslogs.  I ran a few quick tests here and these are the specific syslogs you should be on the lookout for.
Configuration Changes
%ASA-5-111008: User 'enable_15' executed the 'class-map test' command.
http://www.cisco.com/en/US/docs/security/asa/asa82/system/message/logmsgs.html#wp4769400
This notification level syslog will be issued whenever someone issues a command on the ASA.  Note that if you are logging in and then using the enable command the username will always show up as enable_15.  Users must use the "login" command and authenticate again to retain their username.
Failed Logins
%ASA-6-113015: AAA user authentication Rejected : reason = Invalid password : local database : user = scott
%ASA-6-611102: User authentication failed: Uname: scott
http://www.cisco.com/en/US/docs/security/asa/asa82/system/message/logmsgs.html#wp4774576
611102 identifies when an authentication for connections to the ASA fails.
I hope this helps in tracking down those syslogs.
-Scott
Overall Rating: 5 (1 ratings)
Correct Answer
scbrinke Fri, 08/27/2010 - 08:22
  • Cisco Employee,
Hi Shawn,
Failed Logins
-Scott
smjaggers Fri, 08/27/2010 - 09:03
Thanks!  I guess I wasn't formatting my queries to the syslog server right, our solution is not the most user friendly.  I was able to find each of the classes I needed, starting with the 111008 message you specified below.  Thanks for the help.
Shawn
