Unable to load IPS 4240 IOS from Rom Mode
arekemase
Hi Experts,
Kindl asist me in load the IPS IOS on the IPS 4240 from rommon mode.
Note: I can only access the IPS via rommon only becuase the existing ios is cuppted and formatted.
The rommon output is give bellow:
rommon #2> set
ROMMON Variable Settings:
  ADDRESS=192.168.2.16
  SERVER=192.168.2.58
  GATEWAY=192.168.2.1
  PORT=Management0/0
  VLAN=untagged
  IMAGE=C:\IOS\Tftpd32\IPS-4240-k9-sys-1.1-a-6.1-1-E2.img
  CONFIG=
  LINKTIMEOUT=20
  PKTTIMEOUT=4
  RETRY=20
rommon #14> ping 192.168.2.16
Sending 20, 100-byte ICMP Echoes to 192.168.2.16, timeout is 4 seconds:
Success rate is 0 percent (0/20)
rommon #15> ping 192.168.2.58
Sending 20, 100-byte ICMP Echoes to 192.168.2.58, timeout is 4 seconds:
Success rate is 95 percent (19/20)
rommon #0> ping 192.168.2.1
Sending 20, 100-byte ICMP Echoes to 192.168.2.1, timeout is 4 seconds:
Success rate is 100 percent (20/20)
rommon #1> ping 192.168.2.16
rommon #2>
The major problem is that i cannot ping the ips interface address  192.168.2.16) while i can ping all the others.
Thanks in anticipation!
7 Replies 7
Allen P Chen
Level 5
Level 5
It is OK for the sensor to not be able to ping its own interface in ROMMON mode.  Based on the output, it looks like the sensor is able to ping the server at 192.168.2.58.  Are you having issues with the TFTP process?  What happens when you issue the "tftp" command?
Hi Allen,
Here is the output when i issue tftp command at rommom mode:
TFTP failure: Rx TFTP Error Packet
  TFTP OP Code: Error Packet
  Error Msg: File not found
Thanks In anticipation for your responds Allen!
From the error message the file was not found on the tftp server.
I see that you have:
I am guessing that this should be:
  IMAGE=IPS-4240-k9-sys-1.1-a-6.1-1-E2.img
as the tftp daemon on your machine probably is using  C:\IOS\Tftpd32\ as the 'root' directory of the files it is serving.
You can check this in the settings of the tftp daemon.
Best regards, Peter
The root directory for the ios on my TFTP Server is :C:\IOS\Tftpd32\
Best Regards
Hello again,
Ok, so does 'IMAGE=IPS-4240-k9-sys-1.1-a-6.1-1-E2.img' work?
If not what messages do you get?
Best regards, Peter
Wow this solved my issue. Thank you.
arekemase
Thanks man,
Its Working. I really appreciate alot.
Best Regards
