3560 Switch SFP
Aug 27th, 2010
Hello
i have a CISCO 3560 switch with 4 SFP ports.  I need to connect these uplinks to IBM server using cat5e cables so that link will be 1000Mbps.
what are the other connectors i need to use with SFP ports?
roshanverg Fri, 08/27/2010 - 10:04
is glc-t bundled with 3560 or do i need to fix it seperately?
Jerry Ye Fri, 08/27/2010 - 10:07
  • Cisco Employee,
Bundle? Do you mean are they come with the switch by default? The answer to my question is no, because you can buy either fiber or copper SFP.
jerry
roshanverg Fri, 08/27/2010 - 23:38
how many GLC-T Modules need for this ( i.e 1 for each SFP port?)
Hitesh Vinzoda Fri, 08/27/2010 - 23:47
  • Silver, 250 points or more
one per each sfp port...
Hitesh Vinzoda
