Calls per Hour Historical Report
Aug 27th, 2010
I can find nothing on a calls per hour report for the entire day.  Seems like it would be a canned report, but there is nothing there.  Any help?
Cisco Application Administration - 5.0(1)SR02ES01_Build013
Thanks.
Aaron Harrison Fri, 08/27/2010 - 10:34
  • Community Spotlight Award,
    Member's Choice, May 2015
Hi There...
Take a look at the 'Contact Service Queue Something or Other By Interval' report. Select that, then on the 'Detail' tab set the interval to 60 minutes.
Aaron
Please rate helpful posts...
