WVC200 Camera
I need to change my cameras ip address manually from the default 192.168.1.108 to 192.162.1.115 While keeping it set at DHCP and NOT Fixed
Level 3 support helped me with getting to this a long time ago but as you know this camera is no longer supported.
Any suggestions are greatly appreciated.
Glenn Quesenberry Wed, 09/01/2010 - 08:24
If you're using DHCP for IP address assignment then you'll need to configure your DHCP server to assign that address to the camera likely based on MAC address if available on your DHCP server.  The only way to assign a specific IP address on the camera interface is to use "fixed IP address" configuration.  With DHCP option the camera is at the mercy of the DHCP server for IP address assignment.
