08-27-2010 02:08 PM - edited 03-11-2019 11:31 AM
Is it possible with IOS Trend Content filtering to block all websites from specific users except only from 2-3 sites?
08-27-2010 02:24 PM
I believe so. I haven't tried it but you
can follow the example here:
https://supportforums.cisco.com/docs/DOC-8028#_Filtered_Hosts_ClassMap_
You can allow only the 3 sites (by destination IP address from these source computers IP add) so, it won't filter those.
-KS
08-28-2010 02:52 PM
I do not think you can achieve this with IOS content filtering as there is no option of blocking web access based on User policies.
- AD
08-29-2010 02:49 AM
Based on document (DOC-8028) there is an option to filter specific hosts based on ACL.Therefore you can specify the users based on their IP address.
This class map is where the traffic to be filtered is matched. It can be based on protocols and ip addresses defined in ACLs.
class-map type inspect match-all filtered-hosts
match protocol http
match access-group 123
What I am thinking is how can I block all websites? Does the below command can block everything?
parameter-map type urlf-glob url-blacklist
pattern *
