VPN Client
Aug 27th, 2010
I just upgraded to an ASA5520.  More or less everything has been going well.  I have a user in a SOHO with a small home network.   On his laptop once he enables his VPN he can not access his laptops printer or RDP into it.  I have split tunneling enabled.  I am not sure why this is happening?
manish arora Fri, 08/27/2010 - 14:57
Seems like his soho network and you  vpn local pool are on same
rfc 1918 subnet.
Manish
HMidkiff Fri, 08/27/2010 - 15:45
Manish:
Thanks for replying to me post.
I thought the same thing.  His SOHO network is 192.168.11.0.24 and the VPN is 10.2.200.0/24.  I am very puzzled by it.  I am going to try and recreate it in a lab.
Harrison
manish arora Fri, 08/27/2010 - 15:59
Check for following command in your configuration under the group policy attributes then :-
split-tunnel-policy excludespecified
split-tunnel-network-list value local-access
also need an access list for this :-
access-list local-access standard permit host 0.0.0.0
hope it helps
Manish
terrygwazdosky Sat, 08/28/2010 - 05:21
Just a shot in the dark, but does the user have the "allow local lan access" box checked on his VPN client?
