This discussion is locked
ASK THE EXPERTS - DIGITAL MEDIA SUITE
Aug 27th, 2010
  • Gold, 750 points or more
Welcome to the Cisco Networking  Professionals Ask the Expert conversation. This is an opportunity to learn more about the Digital Media Suite and get an update on the new 5.2.x features with Tomas de Leon.  Tomas de Leon is a Technical Leader in the Customer Advanced Engineering Group at Cisco, supporting various emerging technologies through product testing and field trials. He is also a subject matter expert for Cisco in the area of digital media and media processing and assists with network design, documentation, and troubleshooting for critical deployments.  He holds a bachelor of business administration degree in computer information systems and holds CCIE certification #2202 in Routing & Switching.
Remember to use the rating system to let Tomas know if you have received an adequate response.
Tomas might not be able to answer each question due to the volume expected during this event. Our moderators will post many of the unanswered   questions in other discussion forums shortly after the event. This  event  lasts through September 13, 2010. Visit this forum often to view  responses  to your questions and the questions of other community  members.
Overall Rating: 4.8 (6 ratings)
sirivoravith Fri, 08/27/2010 - 23:25
Hi tomas,
Do Cisco Digital signate had solution for interactive video? we 're looking for solution that using DMM to integrate with interactive video by load content (Flash/Web/or any interactive applicaton) direct to DMP box, but not sure about this possibity to do so , any recommend?
Tomas De Leon Sat, 08/28/2010 - 04:03
  • Cisco Employee,
In DMS 5.2.x, the DMPs support Touchscreen displays.   With this feature, you can or a Cisco Partner
can develop touchscreen applications or presentations in order to create and interactive user
experience.
The enclosed DMP data sheet lists the Supported Systems & Vendors for Touchscreen
displays.
http://www.cisco.com/en/US/partner/prod/collateral/video/ps9339/ps7220/data_sheet_c78-480272.html
I hope this answers you question!
Cheers!
T.
yussetamayo Mon, 08/30/2010 - 14:03
Hello
I want to deploy Cisco Show and Share but I am not really what exactly I need.
Can I deploy just in One server? along with DMM+ CAST or is mandatory have two servers?
Could you explain how it is?
Tomas De Leon Mon, 08/30/2010 - 19:48
  • Cisco Employee,
Yusset,
This is a question and a discussion that you should be having with your Cisco Sales Rep, Cisco
Account Team, or Cisco Partner.  Please contact them to better discuss your needs and options.
That said, I will try to give you an overview of the what is needed minus the details of all of the
costs, part numbers, licenses, etc... all needed to place an order etc...
A good start for you is to read the Data Sheet on Show and Share.  The information provided
here will give you the generic overview of what is needed.
http://www.cisco.com/en/US/prod/collateral/video/ps9339/ps6681/data_sheet_c78-565776.html
For Show and Share (SnS), Digital Media Manager (DMM), and Cast, You will need two appliances.
The DMM\Cast\Digital Signage is one appliance.  The SnS is a separate appliance.
Depending on your needs will determine which model of each appliance that you will need to purchase.
In addition to the appliances, you may need a Server (Web & App) to store and serve you DMS
content.  This will also be determined based on your needs and requirements.
So with the information that you provide you will need at least 2 appliances and maybe a UCS server
for store and serve content or host applications like etc...
Take a look a the data sheet for SnS listed above and you can browse the other data sheets if necessary.
Then, as mentioned above, contact your local Cisco Sales Representative for specifics...
Cheers!
T.
Tomas De Leon Tue, 08/31/2010 - 05:34
  • Cisco Employee,
Ambi,
Currently (DMS 5.2.1), High Availability(HA) is not available.
A Cold Standby is the only redundancy or backup at this
time.
HA is on the roadmap and ** SHOULD ** be a feature in an
upcoming release.  I do not have a timeframe for the feature but
is should be real soon.  Stay tuned.
Cheers!
T.
yussetamayo Tue, 08/31/2010 - 06:56
Thanks Tomas.
I just want to be sure I need two appliances. One for the DMM and One for SnS.
The reason I am confuse is because the following:
- On the server Hosting DMM you still need to add the SnS Module and as a option the live evente Module.
- No matter is you have de SnS appliance with the rigth software and licence, you still need the SnS module on the DMM appliance?
thanks a lot.
Tomas De Leon Tue, 08/31/2010 - 07:31
  • Cisco Employee,
Yes, the SnS module is part of the licensing and integration between the
the DMM & SnS appliances.  The appliances pair together.
If you have a DMM without the SnS module, you have a DMS solution
for Digital Signs & Cast.
In summary, you will need 2 appliances (DMM & SnS) and all of the appropriate
modules and licenses for the DMM to manage the integration between the DMM
and the SnS.
As noted above, Your Cisco Partner or Cisco Sales\Account Team will assist
you in preparing your Bill of Materials for your specific DMS Needs.
Cheers!
T.
wesleyj84 Tue, 08/31/2010 - 12:36
I have a DMP 4400 and I'm trying to control display power on and power off with the rs232 serial port. I have a non cisco display.
I used the following set command in advance task on DMM 5.2.1 to activate rs232 functionality on a specific DMP:
init.startService_rs232=yes&rs232.device=/dev/ttyS1&mib.save=1&mng.reboot=1
After the DMP reboots, it starts operating at a much slower speed. It takes several minutes for the startup splash screen to disappear. After that finally happens, my content takes an unacceptable amount of time to load. It can take a minute or too for my content to load from the initial screen wipe from black, which also occurs at a snails pace. Even after all that the rs232 controls aren't ever leaving the port. I hooked it to my laptop and confirmed this.
If I deactivate rs232, the DMP begins operating at normal speed. I also ran the same command on a DMP 4305. It worked just fine. I had total control over the TV.
Does anyone have any idea?
Thanks in advance.
Tomas De Leon Tue, 08/31/2010 - 15:17
  • Cisco Employee,
Wesley,
I have not seen this issue personally, but did see a case where another
customer has the same issue.  The problem actually turned out to be the
RS232 cable itself.
The customer had multiple DMPs configured for RS232 and was only experiencing
the issue on one DMP.  The Cables tested fine and the pinouts within specification.
After swapping the cable from a working configuration to the DMP experiencing the
slowness, the DMP performed as expected.
* So one suggestion would be to try the serial cable from another DMP configuration.
* Another thing to try is to reset or restore the problem DMP to factory defaults. After it
reboots, reconfigure as needed to work in your DMS environment.  Then, test your content
prior to adding RS232 support.  After the content is played as expected, configure the DMP
for RS232 support and test the content performance again.
If the problem persists, please provide the detailed output of the "status" mib for the
DMP in question.
T.
Tomas De Leon Wed, 09/01/2010 - 22:39
  • Cisco Employee,
Tulga,
My apologies, but I do not work on the Security products like
Cisco Ironport.  Are you sure you posted your question in the
correct forum?
Did you mean to post your questions in the other active
Ask the Expert session?  (CCIE Security
with Yusuf Bhaiji)
You may want to post your question in that forum.
T.
Tulga Bat Wed, 09/01/2010 - 22:48
Delete it please!
tnpollock Thu, 09/02/2010 - 10:33
Is there a SRND out for DMS yet?
tnpollock
Tomas De Leon Thu, 09/02/2010 - 10:53
  • Cisco Employee,
tnpollock,
There is not a SRND specific document for Digital Media Suite.
The are application notes, migration guides, and best practices information
for specific components and features.
Is there something specific that you are looking for?
T.
tnpollock Fri, 09/03/2010 - 02:43
I am looking for a document which cuts through all of the marketing stuff and discusses DMS more in-depth from a technical perspective.  It appears Gary's link may accomplish this.
Appreciate the reply!
tenaro.gusatu.novici Fri, 09/03/2010 - 05:13
Hi there,
it is possible to use built-in WiFi, which is part of new DMP, as an access point?
What I'm trying to say is that I can use my laptop to connect to some access point; still, it is possible (via couple clicks inside my operating system) to change this and my laptop will behave as access point allowing other wireless users to connect to my laptop and maybe proceed to Internet via ethernet cable which is also connected to my machine. Is same available on the DMP?
Best regards,
Tenaro
panayiotiscy Fri, 09/03/2010 - 05:26
Hi Tomas,
Congrats for this thread!
I would like to ask you the following:
What is the expected behaviour of the DMP if the content is played from the local storage on the DMP and all of a sudden the connectivity to the DMM is down for any reason?
What i have experienced here is that the content freezes, but i would have expected not to.
Please elaborate!
Thank you
Tomas De Leon Fri, 09/03/2010 - 08:59
  • Cisco Employee,
panayiotiscy,
AFAIK, the expected behavior should be that the locally playing asset **should** continue
to play.  I have tested on my DMP-4400G and it does continue to play.
My initial test was to play the local asset and then pull the ethernet cable on the DMP.
The asset continued to play without issue.  I will try looping the content and see if it
changes over a longer time period and let you know.
What DMP version are your running?
What DMP Model are you testing with?
What were the details of your testing so I can try to replicate here?
What type & format of your content were you running when this occurred?
Also, can you please upload a text file with the output of the "status" mib for
the DMP having issues.
T.
panayiotiscy Mon, 09/06/2010 - 05:20
Hi Tomas,
Actually, what really happens on the dmp is that if the content that is stored in the internal memory  includes a dynamic asset (e.g an html ticker) , then by pulling out the network cable then the whole content freezes. If the content are just assets stored in the internal memory then by pulling out the network cable  the content is not affected.
Still, is the 1st case result an expected one?
Thank you
Tomas De Leon Mon, 09/06/2010 - 09:37
  • Cisco Employee,
I will need to test this scenario and let you know a little later.
Obiviously, since the content is an HTML asset that is
not on the DMP some type of timeout or error will occur
when the network is NOT available for whatever reason.
So my next question to you is does the Ticker freeze or
does then "entire" presentation freezes?
I will let you know what I find out from my testing.
T.
Tomas De Leon Tue, 09/07/2010 - 11:46
  • Cisco Employee,
I tested your scenario and can reproduce the problem.
The problem appears to be definitely related to the
remote URL asset.
I have filed a CDET (bug) on this issue.
CSCti79413 - Locally Presentation freezes after network connectivity is lost
The DMP is probably working as designed with not playing the
presentation when the remote URL is not present.
That said, the issue needs to be addressed at the DMM or DMP level.
You should have seen a "Warning" in the Deployment status window on the
the DMM.  The warning would have notified you of an INVALID Target (the remote
URL).  That said, the DMD should have not been deployed or that portion
of the DMD presentation omitted.
or
the DMP simply continue to play the locally stored assets in the presentation and
just fail on the remote URL asset.
That is something the DMS Engineering Team will need to decide.
I would as a best practice not include Remote URLs for content on a locally stored presentation.
I hope this helps!
T.
panayiotiscy Wed, 09/08/2010 - 22:55
Let's wait for the DMS engineers then to sort this out.
Thank you
Stoyan Stoitsev Tue, 09/07/2010 - 00:21
  • Bronze, 100 points or more
Hello Tomas,
Is there a recommended web server to use with DMS?
Stoyan
Tomas De Leon Tue, 09/07/2010 - 07:38
  • Cisco Employee,
Stoyan,
The following comment is from the "Release Notes of DMS 5.2.1"
"Compatibility Limitations with Microsoft Internet Information Server (IIS)
DMPs that use firmware release 5.2 are compatible with only one version of
Microsoft Internet Information Server. That supported version is IIS 6.0 for
Windows 2003 Enterprise.
If you do not have the supported IIS version but want your DMPs to retrieve
assets from a webserver, we recommend that you use Apache instead of IIS."
Release Notes for Cisco Digital Media Suite 5.2.x
http://www.cisco.com/en/US/docs/video/digital_media_systems/5_x/5_2/dms/release/notes/dms52rn.html#wp103325
I have used the supported version of IIS and Apache with no issues to date.
If this answers your question, Please take time to rate the response.
Thank You!
T.
Teleplex1 Thu, 09/09/2010 - 12:02
I'm currently using DMP 4400-G with version 5.2.1 running on the DMM and the DMPs.  My question is that when we try and use the canned transitions  in the DMD they do not run smoothly on the DMPs.  I see that there is a bug report on this, CSCtg92808 and the listed workaround " use the no effect option" is not really a workaround.  Is this something that is or will be corrected in future upgrades?
Tomas De Leon Thu, 09/09/2010 - 14:17
  • Cisco Employee,
Alan,
Some things to try:
- Make sure Caching is enabled on the DMP
- Try using a "All Media Type" Playlist instead of the Slideshow.
  There will be no transition effect but the performance may be better
  an then you can play with the preload buffer value in the playlist and
  maybe this will help.
- Make sure video failover is disabled.
- And try deploying the slideshow or playlist presentation to the DMP.
  Store it locally and the try playing the presentation to see if there are improvements.
As for future releases, as you mentioned there are some transition issues, The DMS
Engineering team is always trying to make the user\DMS experience better so I am
sure the team will be working on improvements for each upcoming release.  Please
keep monitoring the DMS site on www.cisco.com for upcoming announcements and
features...
If this answers your question, Please take time to mark this
discussion answered & rate the response.
Thank You!
T.
Tulga Bat Wed, 09/01/2010 - 19:26
Delete it please!
Related Content
