switch congestion (42) in Gateway
Aug 27th, 2010
Hello I  need to know why I get this message from IP Phone 'High Traffic Try Again Later'
08/27/2010 17:03:59.326 CCM|StationD: (0550100) StopTone.|<CLID::StandAloneCluster><NID::10.40.7.2><CT::5,100,65,1.60517915><IP::10.40.5.250><DEV::csfigueroa2><LVL::State Transition><MASK::0020>
0808/27/2010 17:03:59.326 CCM|StationD: (0550100) StopTone.|<CLID::StandAloneCluster><NID::10.40.7.2><CT::5,100,65,1.60517915><IP::10.40.5.250><DEV::csfigueroa2><LVL::State Transition><MASK::0020>
08/27/2010 17:03:59.327 CCM|StationD: (0550100) StartTone tone=37(ReorderTone), direction=0.|<CLID::StandAloneCluster><NID::10.40.7.2><CT::5,100,65,1.60517915><IP::10.40.5.250><DEV::csfigueroa2><LVL::State Transition><MASK::0020>
08/27/2010 17:03:59.327 CCM|StationD: (0550100) SelectSoftKeys instance=1 reference=91303033 softKeySetIndex=8 validKeyMask=fffffffb.|<CLID::StandAloneCluster><NID::10.40.7.2><CT::5,100,65,1.60517915><IP::10.40.5.250><DEV::csfigueroa2><LVL::State Transition><MASK::0020>
08/27/2010 17:03:59.327 CCM|StationD: (0550100) DEBUG- star_DSetCallState(11) State of cdpc(361043) is 6.|<CLID::StandAloneCluster><NID::10.40.7.2><CT::5,100,65,1.60517915><IP::10.40.5.250><DEV::csfigueroa2><LVL::Detailed><MASK::0020>
08/27/2010 17:03:59.327 CCM|StationD: (0550100) DisplayNotify timeOutValue=10 notify='€J' content='High Traffic Try Again Later' ver=8570000f.|<CLID::StandAloneCluster><NID::10.40.7.2><CT::5,100,65,1.60517915><IP::10.40.5.250><DEV::csfigueroa2><LVL::State Transition><MASK::002
This sh call history voice call brief
220E : 2694988 30195887000ms.2458674 +-1 +2880 pid:9010 Originate 0916496644
dur 00:00:00 tx:0/0 rx:0/0 2A (switch congestion (42))
Telephony 4/0/0:0 (2694988) [4/0/0.14] tx:0/0/0ms None noise:0dBm acom:0dBm
long duration call detected:n long dur callduration :n/a timestamp:n/a
220E : 2694987 30195886650ms.2458675 +-1 +3230 pid:0 Answer 79999
IP 0.0.0.0:0 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g729r8 pre-ietf TextRelay: off
media inactive detected:n media contrl rcvd:n/a timestamp:n/a
anyone can help me?
Steven Holl Sat, 08/28/2010 - 06:52
  • Cisco Employee,
Can you get more information as the issue occurs?  We need to see if CM is throwing the disconnect of 42, or if the gateway is.
debug voip ccapi inout
debug ccsip mess
debug h225 asn1
Router(config)# service sequence
Router(config)# service timestamps debug datetime msec
Router(config)# logging buffered 10000000 7
Router(config)# no logging con
Router(config)# no logging mon
Router(config)# voice iec syslog
Router# term len 0
Router# sh logg
Note calling/called number of the call with the issue.
santiago_figuer... Sat, 08/28/2010 - 20:26
Hello Steven I get this debugs:
debug h225 asn1
debug h245 asn1
debug ip tcp trans
debug vpm sig
debug isdn q931
The calling Party is 79999, the called party is a 0916496695.
Could you please tell me what may the reason for Value:42?
Could you please tell me  who is  sending a release complete ?
could you please with the  information in that output to diagnose root cause?.
Thanks.
Steven Holl Mon, 08/30/2010 - 06:50
  • Cisco Employee,
Santiago,
The disconnect is being thrown because we are receive an R2_stop from the e1r2 circuit:
461831: *Aug 28 21:50:27.953 GDL: R2 Outgoing Voice(4/0): DSX (E1 4/0/0:20): STATE: R2_OUT_PROCESS_B R2 Got Event R2_STOP
461832: *Aug 28 21:50:27.953 GDL: r2_reg_generate_digits(4/0/0:0(21)): Tx digit '#'
461833: *Aug 28 21:50:27.953 GDL: r2_reg_event_proc(4/0/0:0(21)) ABORT_DIGIT_COLLECT
You will want to work with your provider on this to find out why they are sending this message.  Any details the provider can provide you about how the e1-r2 circuit is provisioned will be helpful, as you may need to configure some stuff under the cas-custom subconfiguration to match what the provider is doing.
-Steve
