Need Help with Partitions and CSS
Answered Question
Aug 28th, 2010
Hi All,
I created 3 types of Partitions and CSS for my CUCM setup.
Local PT - Only for Extension and local PSTN dialing
Long Distance PT - calls to long distance and
International PT - calls to international calls.
Same and with Calling search spaces:
Local CSS - Local PT
Long distance CSS - Local PT and Long Distance PT
International CSS - Local PT, Long Distance PT, and International PT
Once I added the lines to thea propriate partitions and CSS I'm not able to make calls. I can make calls only to those numbers in same PT and CSS.
Example:
DN 1000 is in International CSS and PT
DN 1020 is in Local PT and CSS
I'm able to make calls from 1000 to 1020, but not from 1020 to 1000.
Any help provided will be /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} appreciated.
Correct Answer by Steven Holl about 6 years 10 months ago
I don't think you're getting the concept.
It boils down to this:
You have 1000 in International PT.  The calling phone 1020 has Local CSS applied.  Because International PT is not inside of Local CSS, 1020 cannot call 1000.
It's this simple: the partition of the extension you would like to call needs to be in the CSS applied to the calling party.  That's all there is to it.
Change the PT for 1000 to be Local instead of International, and you will be able to call it.
Overall Rating: 5 (1 ratings)
Steven Holl Sat, 08/28/2010 - 06:59
  • Cisco Employee,
The CSS defines who someone can call.
You aren't able to dial from 1020 to 1000.  In this scenario, since 1020 is the calling phone, it looks at 1020's CSS.
You said the CSS on 1020 is the local CSS, which contains the local partition (internal ext and local PSTN).  That means that those are the only phones which 1020 can call.  1020 cannot call 1000 because 1000 is in the international partition, and you didn't put the international partition in the CSS which you applied to 1020.
I'm not sure what your end goal is, but typically you do your outbound calling restrictions with the CSS's like you are doing.  If you want all of your internal phones to be able to call eachother, place all your internal phones in an 'internal' partition and apply the internal partition to all of your CSSs.  If you want some phones to not be able to call other internal extensions, use a new CSS without the 'internal' partition in there.
-Steve
Lulzim Islami Sat, 08/28/2010 - 07:27
That is exactly what I'm doing, I have internal PT and it is applied in all CSS, but for some reason I'm not able to do calls internaly if one extnsion have higher priviledge of CSS.
Correct Answer
Steven Holl Sat, 08/28/2010 - 07:31
  • Cisco Employee,
Lulzim Islami Sat, 08/28/2010 - 07:39
You are right. Once i put all phones to internalPT now everyone is able to call each other, and the CSS defines who, where can make calls.
Thanks a lot, you been very helpful.
