WLAN - LAN Routing
alabedekenny
Hello
I need help on this issue - I'm really at a loss.
My company just bought a new 1811 Wireless router.
I configured lots of stuff on it using CLI (that was quite
interesting I must say!).
I then configured wireless using Cisco Configuration Professional(CCP).
The issue is, the devices on each network could not communicate
that is, I can neither ping from any device connected through wireless
to another device on the LAN, nor the VLAN on the router.
The LAN is connected using a 2960 connected to the Fast Ethernet 1
interface on the router, while thee router VLAN is on the 8-Port
inbuilt switch.
Please what am I missing out? Do I need to configure a routing
protocol and advertise each network? I thought all the devices
could ping one another since it's the same router.
Please note that I could ping ALL d router interface IP addresses
from ALL the devices.
The configuration is pated below:
........Output cut
dot11 syslog
dot11 ssid ADMIN_WIRELESS
vlan 2
authentication open
mbssid guest-mode
ip source-route
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 10.10.10.2
ip dhcp excluded-address 172.17.1.1 172.17.1.9
ip dhcp excluded-address 10.10.10.4
ip dhcp pool ccp-pool
   import all
   network 10.10.10.0 255.255.255.248
   default-router 10.10.10.1
   lease 0 2
ip dhcp pool ADMIN_WIRELESS
import all
   network 172.17.1.0 255.255.255.0
   default-router 172.17.1.1
ip cef
no ip domain lookup
ip domain name yourdomain.com
no ipv6 cef
bridge irb
interface Dot11Radio0
no ip address
encryption vlan 2 key 1 size 40bit 7 C7846CDFA6A6 transmit-key
encryption vlan 2 mode wep mandatory
broadcast-key vlan 2 change 30
ssid ADMIN_WIRELESS
mbssid
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
basic-54.0
channel 2437
station-role root
interface Dot11Radio0.2
encapsulation dot1Q 2 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
encryption vlan 2 key 1 size 40bit 7 1F6A7ED8DF3F transmit-key
ssid ADMIN_WIRELESS
mbssid
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 basic-54.0
channel 5745
station-role root
no cdp enable
interface Dot11Radio1.2
bridge-group 1
interface FastEthernet0
ip address 44.44.44.1 255.255.255.248
duplex auto
speed auto
interface FastEthernet1
ip address 192.168.3.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan1
description $ES_LAN$
ip address 10.10.10.1 255.255.255.248
ip access-group 100 in
interface Vlan2
no ip address
bridge-group 1
interface Async1
no ip address
encapsulation slip
interface BVI1
ip address 172.17.1.1 255.255.255.0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 FastEthernet0
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 23 remark CCP_ACL Category=16
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 100 remark Auto generated by SDM Management Access feature
access-list 100 remark CCP_ACL Category=1
access-list 100 permit tcp 10.10.10.0 0.0.0.7 host 10.10.10.1 eq telnet
access-list 100 permit tcp 10.10.10.0 0.0.0.7 host 10.10.10.1 eq 22
access-list 100 permit tcp 10.10.10.0 0.0.0.7 host 10.10.10.1 eq www
access-list 100 permit tcp 10.10.10.0 0.0.0.7 host 10.10.10.1 eq 443
access-list 100 permit tcp 10.10.10.0 0.0.0.7 host 10.10.10.1 eq cmd
access-list 100 deny   tcp any host 10.10.10.1 eq telnet
access-list 100 deny   tcp any host 10.10.10.1 eq 22
access-list 100 deny   tcp any host 10.10.10.1 eq www
access-list 100 deny   tcp any host 10.10.10.1 eq 443
access-list 100 deny   tcp any host 10.10.10.1 eq cmd
access-list 100 deny   udp any host 10.10.10.1 eq snmp
access-list 100 permit ip any any
access-list 101 remark CCP_ACL Category=1
access-list 101 permit ip 10.10.10.0 0.0.0.7 any
access-list 102 remark CCP_ACL Category=1
access-list 102 permit ip 10.10.10.0 0.0.0.7 any
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
password 7 122A20312D28232A
login
line 1
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
access-class 101 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 102 in
privilege level 15
login local
end
Please help...Im confused.
Thanks for your contributions.
A.K
kyukim
Try to add belows.
conf t
ssid ADMIN_WIRELESS
vlan 2
exit
int vlan 2
exit
KK.
