08-28-2010 11:43 AM
My router at work is „ RV082“ . I have a dyndns-Address and can make a login to the router via internet (DSL): HTTPS://mydomain.dyndns.org.. I have configured a client-access (without group-tunnel-configuration), I have the newest FW 2.0.. and the latest Quick-VPN-Client.
When I try to build a VPN-connection over Quick-VPN-Client I receive always the message: The Remote Gateway is not responding. Do you want to wait? Even when the PC-Firewall is disabled same message. During this time if someone look on the router-side interface he will see under VPN-Access: Client connected!!!!
I tried with a PPTP-connection.. it worked.. But I prefer to have a real VPN-Access; it is actually the reason why I bought this router. Please Help me someone
Grazie mille
Thanks.. Danke sehr
08-31-2010 03:11 PM
I have seen this behavior when the QuickVPN client is run without Administrator rights. I would also guess it can happen if something allows HTTPS but blocks IPSEC.
09-06-2010 03:51 AM
On the RV082 under the Firewall Settings do you have Block WAN Requests disabled? If it's not disabled
please disable it and give the QVPN another try.
THANKS
