Flow between VPN Client and Site-to-Site VPN
Answered Question
Looking for an ASA 8.0 sample configuration for enabling traffic flow between a Cisco VPN remote access client and destination host connected via LAN/Site-to-Site tunnel.  Both remote access client and site-to-site tunnel terminate on the same ASA device.
Thanks in advance.
-Rey
Correct Answer by praprama about 6 years 11 months ago
Hello Rey,
Here is a config example for what you are looking for.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a008046f307.shtml
Hope this helps.
P.S: This uses TACACS+ for authentication which you can substitute with your method of authentication.
Prapanch
Overall Rating: 5 (1 ratings)
Nagaraja Thanthry Sat, 08/28/2010 - 20:10
  • Cisco Employee,
As long as both VPN sessions are working, you can try the configuration below:
access-list nonat permit ip
nat (inside) 0 access-list nonat
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00804675ac.shtml
Hope this helps.
NT
Message was edited by: Nagaraja Thanthry
