Limiting bandwidth on the CE
Aug 28th, 2010
Hello
I need solution to a similar problem , really appriciate if you can help me on this.
I have taken MPLS services from my Service provider they have configured 8Mbps of MPLS bandwidth and 2Mbps of Internet bandwidth(using 2 Vlans) on their PE over a single physical link connecting to my Cisco1841.Please suggest me how i can ensure on the CE that internet users are not using beyond 2Mbps.All the interbet requests are being catered through a fortygate firewall , here is how the setup is.
                 ----- Fortygate Firewall
PE---- CE--
                 ------ LAN
narainarun Wed, 09/08/2010 - 03:33
You can define CAR or policing using MQC and apply it on the internet sub-interface in the CE router.
Using CAR:
1.Define ACL first. Here you can say match any as the entire internet needs to be rate limited
2.Configure this "rate-limit input/output conform-action transmit exceed-action drop under the sub-interface.
refer this for CAR: http://www.cisco.com/en/US/docs/ios/11_1/feature/guide/CAR.html
Alternately you can apply this on the interface where Fortigate is connected for both inbound and outbound. The exceed action is usually drop which you can mark down the IP Precedece/DSCP as well.
Arun
