Can not ping to My 3560 Switch form 2960
Answered Question
Aug 28th, 2010
I am having a strange problem to ping 3560 Switch from my 2960 Switch. Few Days earlier it was working. Both the Switches are having trunk. At my 2960 Switch can only Ping his Valn 1 Ip address. 2560 can not ping 2960 but can ping other network switches and router.
Can you guys help me what is the reason behind this...
Correct Answer by Nagaraja Thanthry about 6 years 9 months ago
The two switches are on different IP subnets.
On 3560:
interface Vlan1
ip address 10.99.43.7 255.255.255.0
no ip route-cache
On 2960:
interface Vlan1
description "Management VLAN"
ip address 10.99.15.5 255.255.255.128
no ip route-cache
So, they cannot talk to each other. One way this could work is if you change
the subnet mask to /16 i.e. 255.255.0.0.
Hope this helps.
NT
Overall Rating: 5 (1 ratings)
Hitesh Vinzoda Sun, 08/29/2010 - 03:10
  • Silver, 250 points or more
Try adding default gateway on 2960
ip default-gateway x.x.x.x
Hitesh Vinzoda
Pls rate useful posts
Nagaraja Thanthry Sun, 08/29/2010 - 07:59
  • Cisco Employee,
Have you checked the trunk to see if you have enabled management vlan? It
would be a good idea to check the output of "show spanning-tree vlan
" command on both 3560 and 2960 and make sure that the
management vlan is in forwarding state on the trunk. Also, you need to check
to make sure that both are pointing to the same MAC address as the
spanning-tree root. My guess is that for some reason, the trunk may not be
allowing the management vlan traffic.
NT
rowin_rollwu Sun, 08/29/2010 - 09:07
Can you provide more detailed information?
Such as configuration or debug information (debug ip packets)
Feng Luo
Correct Answer
Nagaraja Thanthry Sun, 08/29/2010 - 20:36
  • Cisco Employee,
On 3560:
interface Vlan1
no ip route-cache
On 2960:
interface Vlan1
no ip route-cache
Hope this helps.
NT
Md. Sultan Al Arif Sun, 08/29/2010 - 20:55
Hi Nagraja
Thanks for the post. Last few days its worked here with this configuration. I will chnage my Subnet.
Best Regards
Sultan Al Arif
