need info : 3725 router as terminal server
Aug 29th, 2010
friends,
i need to configure 3700 series router as terminal server. any link would be greatful
i see lot of posts with 2500 series being configured as terminal server.
thanks in advance.
Sara
Nagaraja Thanthry Sun, 08/29/2010 - 07:56
  • Cisco Employee,
Configuration of 3700 router as a terminal server is similar to the 2500
configuration. The only difference will be the line numbers (which depends
upon the module you are using and where you have inserted it).
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_ex...
e09186a008014f8e7.shtml
If you issue "show run" it will list the terminal line numbers in the
configuration. Then you can follow the above procedure for remaining
configurations.
Hope this helps.
NT
