cisco ip telephony implementation
Aug 29th, 2010
hi cisco experts how are you all ,
                   jeelane here from india , working as a system administrator i finished ccna ,mcse,
my company wants to deploy ip telephone . this will be my 1st project ,
1st i want explain  about my company network setup .
my current setup is 5 server ,one astro firewall,one wan router 1700, 50 client computer can be incre next 6 month
one headoffice and 80 shop around this world ..
i am planing to deploy ip telephony for company.
1)which version of cisco unify communcation manager will work for my company network setup?
2)can we buy hp server from hp dealer and cucm 8.0 from cisco ?
3)which router and switch need to buy for headoffice and 80 shop ( only 3 computer each shop and one credit card machine (span machine)?
plx experts help me .
soon reply more more appriciate . reply here or send to my email id [email protected]
Overall Rating: 5 (1 ratings)
paolo bevilacqua Sun, 08/29/2010 - 12:51
  • Hall of Fame,
    Founding Member
For so little phones, CME is a better choice. Search data sheet.
In any case, you will need to hire a reputable consultant or certified Cisco partner.
You cannot do this by yourself.
jeelane2001 Sun, 08/29/2010 - 13:13
thank you very much for your reply. i finished my CIPT so i can do that
friend .
please please answer my question .
On Sun, Aug 29, 2010 at 10:51 PM, p.bevilacqua <
philip.e.denton Mon, 08/30/2010 - 07:47
  • Silver, 250 points or more
"In any case, you will need to hire a reputable consultant or certified Cisco partner.
You cannot do this by yourself."
Correct (and rated).
brendand05 Mon, 08/30/2010 - 00:03
I do not doubt your ability and whilst you may be able to deploy/implement the system over time I each the previous users comments that you should get a consultant invloved in the DESIGN stage. You questions are very basic and indicate that you are not familar with the product.
1) You can use either - recommend design consultation
2) Yes you can by server direct from HP and the SW only from Cisco
3) Depends on a lot of factors - recommend design consultation
jeelane2001 Mon, 08/30/2010 - 00:58
thankyou for your reply ,i will hire,
On Mon, Aug 30, 2010 at 10:04 AM, brendand05 <
