WVC210 monitoring software "Missing or corrupted resource files. Please re-install the system to solve the problem."
Aug 29th, 2010
The software is being installed on Windows 7. I tried running the installer as administrator on setup. I also made sure the program settings were Windows XP SP2 and run as administrator. Is there some other way to have it run?
Alan
mpyhala Thu, 09/02/2010 - 10:14
Alan,
This issue is usually related to attempting to load the software on a netbook that does not support the minimum required screen resolution. I have seen the software load with a resolution of 1024x768, but never less than that.
See the following:
https://supportforums.cisco.com/message/3080763#3080763
Let us know if this is the case or not.
