Validation for 3750 stackconfiguration
Aug 29th, 2010
I have a cisco 3750 stack configuration in my env. (two switches are stacked together)
I want to build a quick validation test plan for checking the stackwise configuration. For ex, fail a switch, pull out the stack cables, disable ports in an etherchannel on one switch and so forth.
Does anybody have such test plans for validation documented that they can quickly share?. A rudimentary test plan validating the features will work. Hoping to avoid reinventing the wheel on the validation doc.
thanks!!
Ava
