CAM license issue for two CAS FO box
Aug 30th, 2010
  • Bronze, 100 points or more
I have two CAS pair for wired and wireless (total is 4) but when I upload licenses it shows me server count is 1, should it be mentioned below as 2? plus Im facing issues while adding other CAS pair.(it gives me "SSLManager: server's certificate chain verification failed " error however I have exported/imported CAM/CAS cert to each other.
FlexLM License-Enabled FeaturesStandard Manager License presentManager Failover License presentOut-of-Band Server Count1Out-of-Band Failover Server Count
Faisal Sehbai Mon, 08/30/2010 - 09:02
  • Gold, 750 points or more
Nomair,
How many licenses have you uploaded on the CAM so far? If you have two HA CAS pairs, and one HA CAM pair, it should be a sum total of 3 licenses.
Can you verify? Go to your CAM SSH session, and type the following:
psql -h localhost -U postgres controlsmartdb -c 'select count(*) from flexlm_licenses;'
Faisal
Faisal Sehbai Wed, 09/01/2010 - 03:03
Nomair,
Run this on your CAM and send me the file via email or PM:
\a
\o /root/Licenses.txt
select * from flexlm_licenses;
\q
This will create a file called Licenses.txt in your /root directory on your CAM. You can copy it to your local machine using WinSCP.
Also send me the output of the following command from your CAM (If in HA, then from both of your CAMs labelling which one is primary and which is secondary)
ifconfig eth0
HTH,
Faisal
