VPN failover configuration in Cisco 2851
Aug 30th, 2010
  • Silver, 250 points or more
I have a Cisco 2851 (c2800nm-advipservicesk9-mz.124-25d.bin) Router configured with one site-to-site vpn. Is it possible to configure a failover vpn tunnel on this router?
NAGISWAREN2 Thu, 09/02/2010 - 23:57
Hi.
Its possible to do failover for VPN. What is your requirement? Do you have redundent internet link? I have been working for VPN failover for more than 100 branches to HQ.
Anand Narayana Fri, 09/03/2010 - 00:19
YES i have 2 ISP. VPN is configured with ISP-1 & ISP-2 is just lying idle. So wanted to make use of that for vpn failover. Please let me know the configuration for the same.
NAGISWAREN2 Fri, 09/03/2010 - 00:24
Hi ,
There is nothing much need to configure in VPN. Create ISAKMP policy, tranform set, crypto map and apply to backup ISP interface.
Now the trick is play around at default routing.
Can u provide me your default routing config for both ISP?
rechard_david Sat, 04/16/2011 - 08:32
Dear all,
I would like to continues to ask about this question that VPN failover configuration, so i would like to know how to configure VPN fail over config, At HQ i have one router and two connection(2Wan)  and branches i have one router and two connection too (2Wan) and i can to to failover VPN over ipsec, So i all of you have commant on this please help to show me?
Best Regards,
Rechard
cciesec2011 Sat, 04/16/2011 - 12:15
Anyone preparing for the CCIE Security lab knows that this is a very simple configuration. The key here is the "crypto map vpn local-address lo0" and that the loopback lo0 ip address must be reachable from both sides for the VPN to be established.  Configuration is below:
HQ:
interface g0/0/0
  ip address 1.1.1.1 255.255.255.0
  crypto map vpn
interface g0/0/1
  ip address 1.1.2.1 255.255.255.0
  crypto map vpn
interface lo0
  ip address 1.1.3.1 255.255.255.0
  crypto map vpn
ip address g0/0/2
ip access-list extended branch_1
  permit ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
crypto isakmp key cciesec2011 address 2.2.3.1 no-xauth
crypto iskakmp policy 10
  authen pre
  hash sha
  encr aes 256
  group 5
  life 86400
crypto ipsec trans tset esp-aes 256 esp-sha-hmac
crypto map vpn 10 ipsec-isakmp
  set peer 2.2.3.1
  set trans tset
  set pfs group5
  set security life sec 3600
  match add branch_1
branch_1:
interface g0/0/0
  ip address 2.2.1.1 255.255.255.0
  crypto map vpn
interface g0/0/1
  ip address 2.2.2.1 255.255.255.0
  crypto map vpn
interface lo0
  ip address 2.2.3.1 255.255.255.0
  crypto map vpn
ip address g0/0/2
  ip address 192.168.2.1 255.255.255.0
ip access-list extended HQ
  permit ip 192.168.2.0 0.0.0.255 192.168.1.0 0.0.0.255
crypto isakmp key cciesec2011 address 1.1.3.1 no-xauth
  authen pre
  hash sha
  encr aes 256
  group 5
  life 86400
  set peer 1.1.3.1
  set trans tset
  set pfs group5
  match add HQ
rechard_david Sat, 04/16/2011 - 18:02
Dera Sir,
I'm glad to see you advice and your command,
I would like to show my diagram and i would like to do on my diagram, Could you advice if possible if i do  interface lo0? If have any many branches do i use interface lo0?and you let me me know why we use interface lo0 i not clear about this command ?
Best Regards,
Rechard
rechard_david Sat, 04/16/2011 - 18:03
Dera Sir,
Best Regards,
Rechard
rechard_david Mon, 06/06/2011 - 05:44
Dear All,
Do you have any update on this ?
it very urgent!!! please help !!!
Best Regards,
Rechard
