08-30-2010 01:57 AM
I'm having problems with our ACE Loadbalancer. It doesn't seem to recover after having restarted the Application the last time. I can't rule out having changed something on the Applcation Server, as we had installed a newer Version. I can see that the "gif" is beeing successfully probed. I've trace what is going on, just can't see if I'm missing something. We've always had a problem after starting the Applcation Servers that it takes foreever untill they start getting balanced again.
Can someone look at the Config and tell me if they see a mistake in it?
I have three instances accesst, accesst2 and accesst3. Each instance has 4 Oracle Application Server Containers Deployed on 2 different Apllication Servers. The Site is split between 2 DMZs which are seperated by a Firewall. The Cisco Ace has one leg in each vlan (191 and 195). We always had a problem after taking the Applcation Servers down Updates that it takes forever untill the ACE Server starts blancing agian. For the last 4 Days it hasn't started reblancing yet. As far as I know nothing has changed in the Configuration of the Server (routing or Firewall) or of the ACE. The Firewall Admin said he tried to find the problem, but didn't change anything.
I used ethereal to trace everything and it looks like the ssl Proxy forwards the request to the ACE The Ace passes it on to one of the containers on the Application server and the application server tries to give it back directly to the ssl server and fails. It should be going through the ACE loadbalancer to pass it back due to a url rewrite. Neither the ACE nor the SSL gets a answer.
Do I maybe have a mistake in the ACE Config? Am I missing something here?
MS4_ACE_PU/MY-APP# sh running-config
Generating configuration....
logging buffered 7
access-list anyone line 8 extended permit ip any any
probe http HEAD_1
port 7791
interval 10
faildetect 15
passdetect interval 15
receive 2
request method head url /APPLICATION/images/probe.gif
expect status 200 200
open 2
probe http HEAD_2
port 7792
interval 5
faildetect 15
receive 2
open 2
probe http HEAD_3
port 7793
interval 5
faildetect 15
receive 2
open 2
probe http HEAD_4
port 7794
interval 5
faildetect 15
receive 2
open 2
probe http HEAD_5
port 7795
interval 5
faildetect 15
receive 2
open 2
probe http HEAD_6
port 7796
interval 5
faildetect 15
receive 2
open 2
probe http HEAD_7
port 7797
interval 5
faildetect 15
receive 2
open 2
probe http HEAD_8
port 7798
interval 5
faildetect 15
receive 2
open 2
parameter-map type http PERSIST-REBALANCE
persistence-rebalance
action-list type modify http LOCATION-RW-VIP-2
header rewrite response location header-value "http://accesst3.my-site.de:.....(.*)" replace "https://accesst3.my-site.de/%1"
header rewrite response content-lokation header-value "http://accesst3.my-site.de:.....(.*)" replace "https://accesst3.my-site.de/%1"
action-list type modify http LOCATION-RW-VIP-1
header rewrite response content-lokation header-value "http://accesst2.my-site.de:.....(.*)" replace "https://accesst2.my-site.de/%1"
header rewrite response location header-value "http://accesst2.my-site.de:.....(.*)" replace "https://accesst2.my-site.de/%1"
header rewrite response location header-value "http://accesst.my-site.de:.....(.*)" replace "https://accesst.my-site.de/%1"
header rewrite response content-lokation header-value "http://accesst.my-site.de:.....(.*)" replace "https://accesst.my-site.de/%1"
rserver host server103
description KS ApplicationServer
ip address 10.200.105.33
inservice
rserver host server104
ip address 10.200.105.34
inservice
serverfarm host HTTP-APPL
rserver server103 7791
probe HEAD_1
inservice
rserver server103 7792
probe HEAD_2
inservice
rserver server104 7791
probe HEAD_1
inservice
rserver server104 7792
probe HEAD_2
inservice
serverfarm host HTTP-APPL-1
rserver server103 7795
probe HEAD_5
inservice
rserver server103 7796
probe HEAD_6
inservice
rserver server104 7795
probe HEAD_5
inservice
rserver server104 7796
probe HEAD_6
inservice
serverfarm host HTTP-APPL-2
rserver server103 7797
probe HEAD_7
inservice
rserver server103 7798
probe HEAD_8
inservice
rserver server104 7797
probe HEAD_7
inservice
rserver server104 7798
probe HEAD_8
inservice
sticky http-header TranSON_Cert_Subject group1
replicate sticky
serverfarm HTTP-APPL
sticky http-header TranSON_Cert_Subject group2
replicate sticky
serverfarm HTTP-APPL-1
sticky http-header TranSON_Cert_Subject group3
replicate sticky
serverfarm HTTP-APPL-2
class-map type http inspect match-any HTTP-INS-VIP
2 match header Host header-value "accesst.my-site.de"
class-map type http inspect match-any HTTP-INS-VIP-1
2 match header Host header-value "accesst2.my-site.de"
class-map type http inspect match-any HTTP-INS-VIP-2
2 match header Host header-value "accesst3.my-site.de"
class-map match-all HTTP-VIP
2 match virtual-address 10.200.101.64 tcp eq www
class-map match-all HTTP-VIP-1
2 match virtual-address 10.200.101.68 tcp eq www
class-map match-all HTTP-VIP-2
2 match virtual-address 10.200.101.69 tcp eq www
policy-map type loadbalance first-match HTTP-SF
class class-default
sticky-serverfarm group1
action LOCATION-RW-VIP
policy-map type loadbalance first-match HTTP-SF-1
class class-default
sticky-serverfarm group2
action LOCATION-RW-VIP-1
policy-map type loadbalance first-match HTTP-SF-2
class class-default
sticky-serverfarm group3
action LOCATION-RW-VIP-2
policy-map type inspect http all-match INS-PM-VIP
class HTTP-INS-VIP
permit
policy-map type inspect http all-match INS-PM-VIP-1
class HTTP-INS-VIP-1
permit
policy-map type inspect http all-match INS-PM-VIP-2
class HTTP-INS-VIP-2
permit
policy-map multi-match SLB-logic
class HTTP-VIP
loadbalance vip inservice
loadbalance policy HTTP-SF
loadbalance vip icmp-reply active
loadbalance vip advertise active
appl-parameter http advanced-options PERSIST-REBALANCE
class HTTP-VIP-1
loadbalance policy HTTP-SF-1
class HTTP-VIP-2
loadbalance policy HTTP-SF-2
interface vlan 191
ip address 10.200.101.65 255.255.255.0
alias 10.200.101.67 255.255.255.0
peer ip address 10.200.101.66 255.255.255.0
access-group input anyone
service-policy input SLB-logic
no shutdown
interface vlan 195
ip address 10.200.105.65 255.255.255.0
alias 10.200.105.63 255.255.255.0
peer ip address 10.200.105.66 255.255.255.0
no shutdown
Destination Gateway Interface Flags
10.200.101.0/24 0.0.0.0 vlan191 IA [0x30]
10.200.105.0/24 0.0.0.0 vlan195 IA [0x30]
This is what I get from sh conn detail:
GSKV_ACE_PU/MY-APP# sh conn detail
total current connections : 4
conn-id np dir proto vlan source destination state
4090142 1 in TCP 191 10.200.101.73:41135 10.200.101.64:80 ESTAB
[ idle time : 00:00:21, byte count : 835 ]
[ elapsed time: 00:00:21, packet count: 3 ]
4090143 1 out TCP 195 10.200.105.33:7791 10.200.101.73:1106 INIT
[ conn in reuse pool : FALSE]
[ idle time : 00:00:21, byte count : 0 ]
[ elapsed time: 00:00:21, packet count: 0 ]
4090158 1 in TCP 191 10.200.101.73:41136 10.200.101.64:80 ESTAB
[ idle time : 00:00:19, byte count : 888 ]
[ elapsed time: 00:00:19, packet count: 3 ]
4090159 1 out TCP 195 10.200.105.33:7791 10.200.101.73:1108 INIT
[ idle time : 00:00:19, byte count : 0 ]
[ elapsed time: 00:00:19, packet count: 0 ]
And sh probe (two Conntainers are disabled because I am trying to land on only one Server to find out what is going on.):
GSKV_ACE_PU/MY-APP# sh probe
probe : HEAD_1
type : HTTP
state : ACTIVE
port : 7791 address : 0.0.0.0 addr type : -
interval : 10 pass intvl : 15 pass count : 3
fail count: 15 recv timeout: 2
--------------------- probe results --------------------
probe association probed-address probes failed passed health
real : mapp103[7791]
serverfarm: HTTP-APPL
10.200.105.33 39197 23318 15879 SUCCESS
real : mapp104[7791]
10.200.105.34 0 0 0 DISABLED
probe : HEAD_2
type : HTTP
state : ACTIVE
port : 7792 address : 0.0.0.0 addr type : -
interval : 5 pass intvl : 15 pass count : 3
real : mapp103[7792]
10.200.105.33 55090 23333 31757 SUCCESS
real : mapp104[7792]
GSKV_ACE_PU/MY-APP# sh service-policy
Policy-map : SLB-logic
Status : ACTIVE
Interface: vlan 191
service-policy: SLB-logic
class: HTTP-VIP
loadbalance:
L7 loadbalance policy: HTTP-SF
Regex dnld status : SUCCESSFUL
VIP Route Metric : 77
VIP Route Advertise : ENABLED-WHEN-ACTIVE
VIP ICMP Reply : ENABLED-WHEN-ACTIVE
VIP State: INSERVICE
curr conns : 1 , hit count : 53
dropped conns : 52
client pkt count : 188 , client byte count: 47195
server pkt count : 0 , server byte count: 0
conn-rate-limit : 0 , drop-count : 0
bandwidth-rate-limit : 0 , drop-count : 0
Parameter-map(s):
PERSIST-REBALANCE
Solved! Go to Solution.
08-30-2010 08:36 AM
Yes you need the nat, If the server uses the firewall as the default gateway then the return traffic to the client will not come back to the ace unless you nat to an address the ace owns. so this is correct .
08-30-2010 08:18 AM
does the server 10.200.105.33 point to 10.200.105.63as its default gateway ?
we see connection to server in INIT state meaning we have not seen a syn-ack back after sending a syn.
Are the servers dual nic ? IF so is nic teaming set to loadbalance or fault tolerant
? if its set to loadbalance we will get failures because the return from the sever could
be from a different mac source than what the ace had as a destination mac when it sent the re
quest . Ace will drop this as a mac spoofing violation. IF nic teaming you always want to
be set for fault tolerant on the server.
08-30-2010 08:25 AM
the Server has a default Gateway pointing to the Firewall. I just changed my Configuration on the ACE so it uses nating like this:
class HTTP-VIP
nat dynamic 100 vlan 195
class HTTP-VIP-1
class HTTP-VIP-2
interface vlan 191
peer ip address 10.200.101.65 255.255.255.0
no shutdown
interface vlan 195
peer ip address 10.200.105.65 255.255.255.0
nat-pool 100 10.200.105.200 10.200.105.200 netmask 255.255.255.255 pat
no shutdown
It seems to work now. I haven't tested it with any load yet though. It would be nice if you tell me if it's set right like this (never did it with natting before).
Thanks for your Help and your answer! I appreciate it.
Jason
08-30-2010 08:36 AM
