4948e portchannel problem
martos1981
Hi all,
I have 4948e and want to make 4x1 Gbps LACP link with AT-9724ts. The AT-9724ts has two working port channels. The 4948e config is:
port-channel load-balance src-dst-mac
interface Port-channel1
description portchannel to at9700
switchport
switchport trunk allowed vlan 133,136,137,921-923,927
switchport mode trunk
interface GigabitEthernet1/2
description portchannel 1
channel-protocol lacp
channel-group 1 mode active
interface GigabitEthernet1/3
interface GigabitEthernet1/4
interface GigabitEthernet1/5
Interfaces staus:
Gi1/2     portchannel 1      notconnect   trunk      a-full a-1000 10/100/1000-TX
Gi1/3     portchannel 1      notconnect   trunk      a-full a-1000 10/100/1000-TX
Gi1/4     portchannel 1      notconnect   trunk      a-full a-1000 10/100/1000-TX
Gi1/5     portchannel 1      notconnect   trunk      a-full a-1000 10/100/1000-TX
Po1       portchannel to at9 notconnect   0            auto   auto
Logging:
Aug 30 14:39:29.289: %EC-5-UNBUNDLE: Interface Gi1/3 left the port-channel Po1
Aug 30 14:39:29.289: %EC-5-UNBUNDLE: Interface Gi1/4 left the port-channel Po1
Aug 30 14:39:29.289: %EC-5-UNBUNDLE: Interface Gi1/5 left the port-channel Po1
Aug 30 14:39:31.237: %EC-5-BUNDLE: Interface Gi1/2 joined port-channel Po1
Aug 30 14:39:31.265: %EC-5-BUNDLE: Interface Gi1/5 joined port-channel Po1
Aug 30 14:39:31.281: %EC-5-BUNDLE: Interface Gi1/4 joined port-channel Po1
Aug 30 14:39:31.285: %EC-5-BUNDLE: Interface Gi1/3 joined port-channel Po1
Aug 30 14:39:31.293: %EC-5-UNBUNDLE: Interface Gi1/2 left the port-channel Po1
Aug 30 14:39:31.297: %EC-5-UNBUNDLE: Interface Gi1/3 left the port-channel Po1
Aug 30 14:39:31.297: %EC-5-UNBUNDLE: Interface Gi1/4 left the port-channel Po1
Aug 30 14:39:31.297: %EC-5-UNBUNDLE: Interface Gi1/5 left the port-channel Po1
Aug 30 14:39:33.137: %EC-5-BUNDLE: Interface Gi1/4 joined port-channel Po1
Aug 30 14:39:33.241: %EC-5-BUNDLE: Interface Gi1/3 joined port-channel Po1
Aug 30 14:39:33.261: %EC-5-BUNDLE: Interface Gi1/2 joined port-channel Po1
Aug 30 14:39:33.313: %EC-5-UNBUNDLE: Interface Gi1/2 left the port-channel Po1
Aug 30 14:39:33.317: %EC-5-UNBUNDLE: Interface Gi1/3 left the port-channel Po1
Aug 30 14:39:33.317: %EC-5-UNBUNDLE: Interface Gi1/4 left the port-channel Po1
Aug 30 14:39:35.157: %EC-5-BUNDLE: Interface Gi1/4 joined port-channel Po1
Aug 30 14:39:35.169: %EC-5-BUNDLE: Interface Gi1/2 joined port-channel Po1
Aug 30 14:39:35.285: %EC-5-BUNDLE: Interface Gi1/3 joined port-channel Po1
Aug 30 14:39:35.329: %EC-5-UNBUNDLE: Interface Gi1/2 left the port-channel Po1
Aug 30 14:39:35.329: %EC-5-UNBUNDLE: Interface Gi1/3 left the port-channel Po1
Aug 30 14:39:35.329: %EC-5-UNBUNDLE: Interface Gi1/4 left the port-channel Po1
Aug 30 14:39:37.033: %EC-5-BUNDLE: Interface Gi1/2 joined port-channel Po1
Aug 30 14:39:37.273: %EC-5-BUNDLE: Interface Gi1/3 joined port-channel Po1
Aug 30 14:39:37.309: %EC-5-BUNDLE: Interface Gi1/4 joined port-channel Po1
Aug 30 14:39:37.333: %EC-5-UNBUNDLE: Interface Gi1/2 left the port-channel Po1
Aug 30 14:39:37.337: %EC-5-UNBUNDLE: Interface Gi1/3 left the port-channel Po1
Aug 30 14:39:37.337: %EC-5-UNBUNDLE: Interface Gi1/4 left the port-channel Po1
Aug 30 14:39:39.101: %EC-5-BUNDLE: Interface Gi1/2 joined port-channel Po1
Aug 30 14:39:39.149: %EC-5-BUNDLE: Interface Gi1/3 joined port-channel Po1
Aug 30 14:39:39.305: %EC-5-BUNDLE: Interface Gi1/4 joined port-channel Po1
Aug 30 14:39:39.353: %EC-5-UNBUNDLE: Interface Gi1/2 left the port-channel Po1
Aug 30 14:39:39.357: %EC-5-UNBUNDLE: Interface Gi1/3 left the port-channel Po1
Aug 30 14:39:39.357: %EC-5-UNBUNDLE: Interface Gi1/4 left the port-channel Po1
Aug 30 14:39:41.105: %EC-5-BUNDLE: Interface Gi1/2 joined port-channel Po1
Aug 30 14:39:41.293: %EC-5-BUNDLE: Interface Gi1/3 joined port-channel Po1
Aug 30 14:39:41.321: %EC-5-BUNDLE: Interface Gi1/4 joined port-channel Po1
Aug 30 14:39:41.369: %EC-5-UNBUNDLE: Interface Gi1/2 left the port-channel Po1
Aug 30 14:39:41.369: %EC-5-UNBUNDLE: Interface Gi1/3 left the port-channel Po1
Aug 30 14:39:41.369: %EC-5-UNBUNDLE: Interface Gi1/4 left the port-channel Po1
Aug 30 14:39:43.085: %EC-5-BUNDLE: Interface Gi1/3 joined port-channel Po1
Aug 30 14:39:43.237: %EC-5-BUNDLE: Interface Gi1/4 joined port-channel Po1
Aug 30 14:39:43.273: %EC-5-BUNDLE: Interface Gi1/2 joined port-channel Po1
Aug 30 14:39:43.377: %EC-5-UNBUNDLE: Interface Gi1/2 left the port-channel Po1
Aug 30 14:39:43.377: %EC-5-UNBUNDLE: Interface Gi1/3 left the port-channel Po1
Aug 30 14:39:43.377: %EC-5-UNBUNDLE: Interface Gi1/4 left the port-channel Po1
Aug 30 14:39:45.093: %EC-5-BUNDLE: Interface Gi1/3 joined port-channel Po1
Aug 30 14:39:45.309: %EC-5-BUNDLE: Interface Gi1/4 joined port-channel Po1
Aug 30 14:39:45.353: %EC-5-BUNDLE: Interface Gi1/2 joined port-channel Po1
Aug 30 14:39:45.397: %EC-5-UNBUNDLE: Interface Gi1/2 left the port-channel Po1
Aug 30 14:39:45.397: %EC-5-UNBUNDLE: Interface Gi1/3 left the port-channel Po1
Aug 30 14:39:45.397: %EC-5-UNBUNDLE: Interface Gi1/4 left the port-channel Po1
I changed the cables already. Any ideas and/or hints?
7 Replies 7
I assume you are connecting servers on this switch will will need your spanning-tree portfast enabled not sure if this will help with this issue, I had a similiare issue with our Nexus 7k but that got resolved. I do alot of portchannels on 3750 but never on a 4948e.
srereddy
Config looks fine. However, looking at the physical int status, you have 'notconnect' against all the gig interfaces. Check if the interefaces are properly connected to the other end and make sure you have 'line protocol up'.
I changed the port configuration to:
channel-group 1 mode on
Aug 31 09:29:45.592: %EC-5-BUNDLE: Interface GigabitEthernet1/2 joined port-channel Port-channel1
Aug 31 09:29:45.600: %EC-5-BUNDLE: Interface GigabitEthernet1/3 joined port-channel Port-channel1
Aug 31 09:29:45.604: %EC-5-BUNDLE: Interface GigabitEthernet1/4 joined port-channel Port-channel1
Aug 31 09:29:45.608: %EC-5-BUNDLE: Interface GigabitEthernet1/5 joined port-channel Port-channel1
But I am not sure it will work correctly. What can I expect from this config?
Well, when you confgure mode to 'ON', irrespctive of the otherside, the switch puts all the ports in to channel. To make the channel work, you need to have the ON mode on the otherside as well. Can you post below command's output.
sh etherCHannel channel-group-number summary
sh etherchannel port-channel
I had to dismiss the portchannel because my time to put in production passed. I will make a vlan based load balance and later will buy another cisco to change the AT.
Thank you for your answers and don't buy AT switches!;)
NP.
PS: Pls rate the answers if you liked.
fundi_yves
hello !
I want to configure two Catakyst switch 4948e those are connected between them
I have seen that you configure yours, can you help me to configure EtherChannel for ports Servers
