VPN failover and failback
Aug 30th, 2010
I have VPN IPSEC configuration to remote site. Now I want to set up some sort of redundancy, or failover or failback techniques. The remote site could be connected by FR as well. I do not know how to design technique such as HSRP, where in the case  the remote site for some reasons is not available, the communication will failover to FR communication?
NAGISWAREN2 Thu, 09/02/2010 - 23:47
Can you give more info.
How many intenet connection your local have? and What type
how many internet connection of your remote site have? and What Type
Is it both connection terminate to same device? And what device are you using?
Jitendriya Athavale Fri, 09/03/2010 - 04:56
  • Cisco Employee,
well all you need to do is apply the crypto map on both the interfaces of the fw having redundant interfaces
and on your end just give 2 peers
