Collecting data statistics on a specific physical port, C3750
Aug 30th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Vanlig tabell"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
Hello everyone,
Using IPM in LMS 3.2.
Have source device C3750/C3400 and target device is C3750 with a valid IOS for IP SLA.
Enabled the responder on a target.
Custom operations are sent from IPM collector.
Generally, UDP-Jitter is working without specifying physical port on a target device.
Can you monitor data statistics (UDP-Jitter) on a specific port on a target device (for example on physical port nr. 6 on C3750?) Or may be one has to specify VLAN on the target device port?
What I tested was just enabling the responder on a target device and sent collector operations (UDP-Jitter) to source device. This is fine. But I want to collect data statistic from a physical port on the target device. Thanks for your help.
Overall Rating: 4 (1 ratings)
Joe Clarke Mon, 08/30/2010 - 11:40
No, this is not possible.  UDP Jitter works over IP, so you have to send responses to a specific IP address.  The UDP packets will arrive at the target through the port that is connected to the upstream route hop (which could be through another L2 switch).  I have a bug open (CSCsz66719) to be able to specify a target address (i.e. target IP address) using IPM, but it has not currently been implemented.
yawena2005 Tue, 08/31/2010 - 23:49
Thanks for the quick respons.
Do I have other options besides using other 3rd party software?
