ACE 4710 rewrite?
Aug 30th, 2010
Hi guys!
I have a question about the header rewrite function of he ACE 4710.
What I want:
A client is accessing following URL: www.cisco.com/paint
Match URL policy say: go to Serverfarm xyz Port xyz
What I want is,  the request will be send to the Serverfarm with another location such /service/axis/check is that possible?
I won’t a redirect, only a rewrite.
Can handle the ACE that? If yes, how can I configure that
Cheers
Markus
jsirstin Mon, 08/30/2010 - 06:30
  • Cisco Employee,
Markus,
Unfortunately the ACE cannot rewrite the URI. It can only rewrite the http headers. The only thing the ACE can do in this case is send a redirect to the correct path you want the user to connect to.
Jim
