vlans across a wan
anand.narine1
I have the following configuration in a lab environment.
SWITCH A  (vlan 2, vlan 3)
RouterA (10.0.0.2 (wan), 192.168.0.1 (lan))
RouterB (10.0.0.1 (wan), 192.168.1.1 (lan))
SWITCH B (vlan 3)
How do I get users on vlan 3 on switch B to talk to
users on vlan 2 and vlan3 on switch A.
SWitch A and B are layer 3 switches
1) Is trunking needed ? IF so, where ?
2) Do I need to assign ip addresses to each vlan interface?
   If so, what can these ip's be ?
11 Replies 11
If you just want users one one side to talk to users on the other side you can accomplish that with routing.
On the other hand,  if you're looking to pass VLAN information through the WAN then there some methods of doing this like L2TPv3 and QinQ.
It all depends on what you want to do.
Federico.
kyukim
You can do it with routing.
You need to configure int vlan and enable routing.
SW1-----vlan2,192.168.0.0/24---R1----10.0.0.0/24-----R2----192.168.1.0/24,vlan3-----SW2
on SW1
int vlan 2
ip add 192.168.0.x 255.255.255.0
router eigrp 1
no auto
net 192.168.0.0 0.0.0.255
on R1 and R2
router eigrp 1
no auto
net 0.0.0.0 0.0.0.0
on SW2
on SW1
int vlan 3
ip add 192.168.1.x 255.255.255.0
router eigrp 1
no auto
net 192.168.1.0 0.0.0.255
KK
why do i not need to make the links between router and switches trunk links ?
On Mon, Aug 30, 2010 at 12:27 PM, kyukim
and also, does vlan 3 need to be in different ip subnets on both switches ?
Whenever the switch is handling more than a single VLAN (two or more), then the connection between the switch and the router should be a trunk.
VLAN 3 should be a different IP subnet on both sides to avoid overlapping (unless you use NAT).
Federico.
so you are saying that if i had vlan 2, 3, on switch A, and vlan 2, 3
on switch B, then the links to the router from each switch would need
to be trunk links right ?
On Mon, Aug 30, 2010 at 1:54 PM, coto.fusionet
If you have VLAN 2, 3 on switch A and VLAN 2,3 on switch B (assuming they are Layer 2 switches and the Inter-VLAN routing is been done by the router on each end..)
then yes...
the connection between the switches and routers should be trunk.
Federico.
no in my case the switches are layer 3 and intervlan routing is on the switches
On Mon, Aug 30, 2010 at 2:02 PM, coto.fusionet
Then,
If you have a Layer 3 connection between the switches and the routers, there's no Trunk concept (the connection is just a Layer 3 connection).
Or if you're using a Layer 2 connection to the router, then it don't have to be a trunk (because the InterVLAN is handled by the switch).
Federico.
So last question.. lets say on switch A, vlan 2 interface has ip
192.168.0.2 /24 and can communicate with the router A on 192.168.0.1
/24
Vlan 3 interface on switch A has a different range eg. 192.168.3.1.
Then how will vlan 3 interface communicate with the router?
Would traffic originating from vlan 3 first go to the vlan 2 interface
then to the router ?
On Mon, Aug 30, 2010 at 2:11 PM, coto.fusionet
You have
VLAN 2 192.168.0.0/24
VLAN 3 192.168.3.0/24
The router has an interface 192.168.0.1
You mentioned that the Layer 3 switch is doing the InterVLAN routing, if so, then the Layer 3 switch should have two SVIs.
interface vlan 2
ip add 192.168.0.2 255.255.255.0
interface vlan 3
ip add 192.168.3.x 255.255.255.0
Then, all the communication between the switch and the router goes through the 192.168.0.0/24 connection.
This is not the only way to do it, but I assume that's how you have it.
Federico.
